Need to do a bunch of welding, Can't do it in my apartment's garage :( |
TonyAKAVW |
Aug 4 2005, 03:22 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
Its come to the point in my Subaru conversion that I need to finish up a lot of welding on the roller. I've got to finish fixing up the hell hole area, and put together an engine support bar, and weld on a front and partial rear fender. Its probalby a full weekend of work, maybe more. The problem is that I live in an apartment and my garage is not wired well.
I've tried using a 110 mig welder, but its pretty clear that the power is just not there. The spark will start and then the voltage on the line drops and the motor slows down. The arc goes away and the motor speeds up. So welding ends up being a series of dots of weld and I cannot seem to get decent penetration. I'm using a very beefy power cord and I even replaced the outlet on the wall. It doesn't help the situation much. Seems like I need to take this car somewhere and do the welding where I have access to the right amount of power at the very least. I don't have the budget to take the car to a shop and have the welding done, and I'd rather do it myself and learn from it. So does anyone want to help? Or anyone have any good ideas on other options? -Tony |
mightyohm |
Aug 4 2005, 04:05 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
If you found a 220V welder, not much.
Your neighbor probably isn't going to like the angle grinder either. Consider moving. |
Lo-Fi Version | Time is now: 1st June 2024 - 03:41 AM |
