fuel pump surging, why?? |
Tab914 |
Aug 1 2005, 06:52 PM
Member Group: Members Posts: 158 Joined: 25-April 04 From: Alexandria, Ontario, Canada Member No.: 1,978 Region Association: Canada |
Another one for you guys...........
Here is the problem I am trying to fix. Whenever the needle in the temp guage gets to about 1/4 the fuel pump starts surging. This causes the idle to start to go up and down in rythm with the fuel pump. Also when under load the car stutters and shudders and kinda wants to choke. Before the car gets up to that temp. it runs nice and smooth, strong on acceleration and no poping or backfiring on decel or anything. Just sounds great and runs fine. Idle is where it should be and fuel pump does not surge. Here is what has been done. -Valve adjustement -Dwell adjustement -Timing adjustement -Tested MPC as per proper ohms. Parts I have changed- coil, plugs, ignition points, trigger points, condenser, rotor, cap and wires. Questions:- what could make the pump surge like that? -does it make a difference how the MPC wire goes into it's conector? -How do I properly check the head temp sensor. -Could the intake temp. sensor be the cause. I am at a lost. Feel like I am going in circles. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Has anyone had this kind of problem?? Desperate for advice. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Thanks, Dominic. forgot to add. car is a 1974 2.0 with stock fuel injection. |
mihai914 |
Aug 4 2005, 09:46 PM
Senior Member Group: Members Posts: 800 Joined: 2-March 05 From: Montreal, QC Member No.: 3,697 Region Association: None |
No it doesn't, I have one up front before the pump and one in the original location before the injectors just for the heck of it and there is no problems whatsoever. When you'll redo the whole thing, the sucky part will be to go from the D port of the pump which is 7mm to the center tunnel feed line which is 9mm, I used a 7mm id fuel hose but it was very hard to get it on the fuel line. The reason to use the 7mm/9mm original filter is because the pickup at the fuel tank is 9mm and of course the S port at the pump is 7mm DUH! so the filter acts as an adapter. I wish I knew of a round 7/9mm filter as the square one takes alot of space under the steering rack. Do whatever it takes to have a look inside the gas tank and see if there is junk there, and it's actually not that hard to get the junk out of there, getting it spotless is another story. |
Lo-Fi Version | Time is now: 1st June 2024 - 11:48 AM |
