> Brake Fade?, Thought I was dead
Trevorg7
post Aug 5 2005, 09:13 AM
Nothing like your brake peddle hitting the floor while exiting the freeway at 65 to get your heart started in the morning.
So, north bound 280 exiting to 92 and my brake peddle hits the floor (IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) !
I manage not to hit anyone and coast to a surface street. After limping down the street a bit, 10 mins, the brake peddle came back and I was able to stop again.
Was this brake fade? Seems unsafe to drive home but????
I've done all brakes in the past three months and bleed the brakes. Could it have been just a bubble I missed or pure brake fade?
Thoughts?
Thanks
T
Dave_Darling
post Aug 5 2005, 04:07 PM
914 Idiot
QUOTE (Porsche Rescue @ Aug 5 2005, 08:11 AM)
The pedal does not go to the floor with fade. It simply requires more pedal pressure while achieving less braking.
There are actuall two kinds of phenomenon that get called "brake fade". The kind you describe here is "pad fade", where the pads simply get too hot to grab the rotor. The pedal stays nice and firm, but the car does not slow at all.
The second kind is "pedal fade"--and that generally happens when you boil the brake fluid. The brakes get more and more soggy, until the pedal just goes straight to the floor and you don't slow down at all.
You can make the second come back by pumping the pedal. Not so the first kind.
I agree that this occurrence isn't one of those.
--DD
Trevorg7   Brake Fade?   Aug 5 2005, 09:13 AM
VegasRacer   'Brake Fade' occurs from heat buildup due ...   Aug 5 2005, 09:20 AM
Trevorg7   Good point. I was a freeway speed for 30 mins with...   Aug 5 2005, 09:28 AM
Mueller   bad mastercylinder?? any leaks @ the fittings? I...   Aug 5 2005, 09:28 AM
goose2   sounds like a master cylinder problem to me   Aug 5 2005, 09:35 AM
mihai914   Also add a sticking piston or rear brake pads too ...   Aug 5 2005, 09:36 AM
Trevorg7   Great feedback guys....so.....questions... would ...   Aug 5 2005, 09:43 AM
seanery   a dragging caliper would most likely cause a pulli...   Aug 5 2005, 09:47 AM
Porsche Rescue   I don't think "fade" applies at all to your ex...   Aug 5 2005, 10:11 AM
goose2   If a piston is sticking, you will feel it when coa...   Aug 5 2005, 10:12 AM
bondo   I'd say if you can't find anything wrong, ...   Aug 5 2005, 10:22 AM
ArtechnikA   <...   Aug 5 2005, 10:31 AM
!   Most likely the MC, also I would consider that in ...   Aug 5 2005, 10:38 AM
URY914   BTW, a MC change is a PITA. http://...   Aug 5 2005, 10:39 AM
Dr. Roger   You did not mention weather nor not you could reco...   Aug 5 2005, 10:41 AM
trekkor   I had true brake fade at Streets of Willow during ...   Aug 5 2005, 10:43 AM
Rough_Rider   Check your lug nust, Seriously.... If any are loos...   Aug 5 2005, 10:46 AM
Trevorg7   Thank you all for the info. To answer more questi...   Aug 5 2005, 12:16 PM
Travis Neff   I had a sticky front caliper and there was just th...   Aug 5 2005, 01:29 PM
trekkor   HPH is where many of us take our cars if we do not...   Aug 5 2005, 01:37 PM
Dave_Darling
- Lo-Fi Version Time is now: 1st July 2025 - 07:04 AM
