> Rear 5-Lug with 944 Parts, PART II, update & pics ...
post Aug 6 2005, 06:01 PM
Resident German
so it looks like there's going to be some minor machining required after all.
turns out, the 944 Turbo CVs are 4mm thicker than the 914 CVs which means the 914 axle shaft has to be machined down a bit for them to fit.
see pictures below ...
(IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy
1 - 914 shaft on top, 944 shaft below
(IMG:http://www.914world.com/bbs2/uploads/post-11-1123372532.jpg)
2 - closeup, for difference, see table below ...
(IMG:http://www.914world.com/bbs2/uploads/post-11-1123372553.jpg)
3 - 4 mm needs to be removed from the 914 shaft to accomodate the 944 CV
(IMG:http://www.914world.com/bbs2/uploads/post-11-1123372569.jpg)
4 - 914 CV on the left, 944 CV on the right
(IMG:http://www.914world.com/bbs2/uploads/post-11-1123372588.jpg)
5 - 914 CV on the left, 944 CV on the right
(IMG:http://www.914world.com/bbs2/uploads/post-11-1123372608.jpg)
Dimensions:
914 Shaft, dia. = 25mm, length = 514mm
944 Shaft, dia. = 26mm, length = 540mm
914 CV, dia. = 94mm, width = 31mm
944 CV, dia. = 100mm, width = 35mm
Type 4 Unleashed
post Aug 8 2005, 12:25 AM
CREATIVE TYPE lV ENGINEERING
Group: Retired Members
Posted: Jun 14 2005, 04:31 AM
My running 914/6 conversion.
Hurst, TX.
QUOTE (John Jentz @ Jun 13 2005, 04:14 PM)
QUOTE (SirAndy @ Jun 13 2005, 05:36 PM)
what if i have 911 hubs that fit the 914 wheel bearing and i use 911 stubaxles and halfshafts and change the drive flanges on the transmission to 75-76 911,
whouldn't that work just fine ???
Only if the c/v's are 100mm and the 911 axles are supposed to be too short anyway. The earlier 108's require the earlier stubs and output flanges. With Cays config the 944 c/v's have the 914 (VW) spline and you could use the 914 axle shafts.
You don't have to change the axle shaft if you use the 944 axles. The 944 and 914 axle shafts are the exact same length.
If you are a cheap bastard, you can buy a 944 stub axle and one CV joint, and put it on the 914 /4 axle. Then use the 914 inner CV and drive flange.
If you want to do it right, use the 944 axle complete, and the 75-76 911 transmission drive flanges.
Oh, and using a 911 axle is asking for a failure. They will bolt up, but if you EVER hit full droop or full compression you WILL bind the CV joint and damage it.
Then you will be out the cost of the 911 axle parts, and your 914 will be back home on the jackstands.
Here, Clay says the 914 & 944 axle are the same length. But Andys pic, shows the 944 axle is longer, is it the right year?
For a 4 cylinder teener, this would be a cheap way to do a 5 lug conversion, once everything is worked out?
For a V8 teener, I wouldn't do the axel and CV upgrade, unless you have a 915 or better tranny.
WHY?
It's cheaper to replace CV's than it is to replace 901's, especially if you've spent money on a intermediate plate and or H gear.
If, you beef up the CV's and axels, to handle more HP
than the week link becomes the tranny.
This is my 500,000 cents, the price of a nice tranny. (IMG:http://www.914world.com/bbs2/html/emoticons/happy11.gif)
SirAndy   Rear 5-Lug with 944 Parts, PART II   Aug 6 2005, 06:01 PM
Travis Neff   Is this per Clay's conversion post? Good info...   Aug 6 2005, 06:11 PM
SirAndy   <...   Aug 7 2005, 12:40 PM
Racer Chris   <...   Aug 7 2005, 12:41 PM
Racer Chris     Aug 7 2005, 12:42 PM
SirAndy   ...   Aug 7 2005, 07:20 PM
SirAndy   UPDATE on the machining of the 914 shaft ... her...   Aug 7 2005, 07:23 PM
Gary   Cool thread! Appreciate your sharing the info....   Aug 7 2005, 07:32 PM
Mueller   wow...I have more hair than I thought   Aug 7 2005, 07:46 PM
Dr Evil     Aug 7 2005, 09:42 PM
seanery   Andy, I bet $5 it's from an 86 turbo, the...   Aug 7 2005, 11:10 PM
V6914   Posted: Jun 14 2005, 04:31 AM My running 914...   Aug 8 2005, 12:25 AM
914Timo   Hmmm..... It looks like 944 CVs are the same as 91...   Aug 8 2005, 12:31 AM
Mueller     Aug 8 2005, 08:40 AM
Aaron Cox   will 69 911 hubs work?   Aug 8 2005, 08:44 AM
ClayPerrine   ...   Aug 8 2005, 10:05 AM
SirAndy     Aug 8 2005, 10:17 AM
ClayPerrine   Added benefit. If the tranny ever does blow, you ...   Aug 8 2005, 01:38 PM
914MF   Do you have to machine both ends of the 914 axle s...   Aug 8 2005, 02:27 PM
Mueller     Aug 8 2005, 02:36 PM
SirAndy     Aug 8 2005, 02:58 PM
914MF   http://www.914world.com/bbs2/...   Aug 8 2005, 03:32 PM
914Timo     Aug 9 2005, 12:41 AM
SirAndy     Aug 9 2005, 12:52 AM
914Timo   According this LINK the width of splined center of...   Aug 9 2005, 12:52 AM
914Timo
  Aug 9 2005, 12:53 AM
SirAndy     Aug 9 2005, 12:55 AM
914Timo
  Aug 9 2005, 07:48 AM
Mueller     Aug 9 2005, 08:22 AM
James Adams     Aug 9 2005, 12:27 PM
neo914-6   What are the relative lengths of 914/911/944 axles...   Aug 18 2005, 02:43 PM
Andyrew   THat renault trani is HUGE!!!   Aug 18 2005, 03:01 PM
neo914-6   <...   Aug 18 2005, 04:40 PM
JOHNMAN
  Oct 12 2005, 12:31 AM
914Timo
  Oct 12 2005, 06:40 AM
914Timo   ... and the pic.   Oct 12 2005, 06:49 AM
ClayPerrine   <...   Oct 12 2005, 08:48 AM
JOHNMAN   I didn't know the 914-6 axle shafts were that ...   Oct 13 2005, 10:53 PM
bondo   <...   Oct 13 2005, 11:47 PM
neo914-6   <...   Oct 14 2005, 12:57 AM
914Timo
  Oct 14 2005, 02:35 AM
Verruckt   Hey guys, what is it that Pelican is using here......   Oct 14 2005, 05:31 AM
redshift   http://www.914world.com/bbs...   Oct 14 2005, 05:56 AM
ClayPerrine   Those are either bus axles or 911 axles with adapt...   Oct 14 2005, 05:56 AM
neo914-6   <...   Oct 17 2005, 01:16 AM
Randal   Had to resurrect SirAndy's classic thread on 9...   Mar 21 2011, 03:43 PM
SirAndy   Had to resurrect SirAndy's classic thread on ...   Mar 21 2011, 07:14 PM
PeeGreen 914   Another trick is to buy nylocks and put them on th...   Mar 21 2011, 04:08 PM
Eric_Shea   And they're really hard to find. A few year...   Mar 21 2011, 05:11 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 02:50 PM
