yet another oil tank thread, vellios vs oe |
blabla914 |
Aug 7 2005, 04:20 PM
I like primer Group: Members Posts: 321 Joined: 1-March 04 From: Connecticut Member No.: 1,740 Region Association: None |
I'm purely interested in the oil control of these two tanks under high cornering loads.
I have a vellios tank purchased from patrick motorsports about 3 years ago. I understand some of the EARLY vellios aluminum tanks had oil control problems, but it was fixed quite some time before I bought mine. However, at the last autocross I caught my oil pressure gauge jumping around. As I came off a medium speed (about 4000rpm in second) corner I saw the oil pressure gauge make a BIG wiggle. I took it a bit easier the rest of the run and I didn't see it do it again. The car had been idling for at least 15-20 min and had roughly 170F oil temp. I also ran the motor at like 2000rpm in staging a bit to make sure the scavenge pump had a chance to empty the case. I verified the level after the run and it was overfull. I can't get the hang of adding oil to this thing to save my life. It's usually a little low when I show up at autocrosses (it's generally the only time I check it, but I autocross quite a bit) and I always add too much. I'm worried it's doing this when I'm not looking, which is normally the case when I'm trying to look where I'm going. I've been trying to keep an eye on it, but it can be tough to push the car real hard when you're looking at the dash, and it seems it doesn't do if unless I push real hard. Know what I mean? I am further worried by a tech response I saw a while back in the panorama where a guy wrote in saying he had popped his -6 at the glen. The first question the tech guy asked was if his car had the factory -6 tank. He didn't necessarily ask if the tank was a vellios, but he say that the factory -6 tank should be adequate for what he was doing. My car has a pretty standard setup with an aluminum tank, no front cooler and -12 aeroquip lines. It's hooked up to a '69 2.0L motor that is mostly E spec. and I use a 7k rpm rev limiter, but shift at 6500 rpm. I'd be interested to hear from you guys who are running on the track or autocross with the aluminum tank that fits in the stock location. Any pickup problems? Any tricks I should know? Thanks for your help. Kelly |
blabla914 |
Aug 8 2005, 04:36 PM
Brant,
You are correct on both counts. We are both talking about the line from the tank to the inlet of the pressure side of the pump that is run through the tube connected to the bottom of the oil cooler. My car does not have a front mounted cooler, so I've only got two lines. A -12 fitting at the bottom of the tank connected to a -16 line that's only 2 or 3 feet long would make very little if any difference. However, that's not my situation. I have an aluminum tank with NPT's in it. Into the NPT's there are NPT to an adapters. Currently I have an NPT of unknown size into a -12 AN fitting running though -12 line to a -12 male fitting welded to the oil cooler. That's the engine mounted oil cooler. That's were things potentially get ugly. I understand guys running 3.0L motors or bigger run an NPT to -16 adapter in my tank to -16 line. The problem is I need to hook the -16 line to the -12 fitting on the engine oil cooler. This may help because the restriction is now much closer to the pump. I stress may since it is still a very short line. Since the line may be collapsing I could now run the anti-collapse springy thingy inside the larger line. I'm going to try the anti-collapse springy thingy first and see if that does the job. Kelly |
Lo-Fi Version | Time is now: 10th June 2024 - 02:13 PM |
