| SirAndy |
Aug 6 2005, 06:01 PM
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,469 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
so it looks like there's going to be some minor machining required after all.
turns out, the 944 Turbo CVs are 4mm thicker than the 914 CVs which means the 914 axle shaft has to be machined down a bit for them to fit. see pictures below ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) Andy 1 - 914 shaft on top, 944 shaft below (IMG:http://www.914world.com/bbs2/uploads/post-11-1123372532.jpg) 2 - closeup, for difference, see table below ... (IMG:http://www.914world.com/bbs2/uploads/post-11-1123372553.jpg) 3 - 4 mm needs to be removed from the 914 shaft to accomodate the 944 CV (IMG:http://www.914world.com/bbs2/uploads/post-11-1123372569.jpg) 4 - 914 CV on the left, 944 CV on the right (IMG:http://www.914world.com/bbs2/uploads/post-11-1123372588.jpg) 5 - 914 CV on the left, 944 CV on the right (IMG:http://www.914world.com/bbs2/uploads/post-11-1123372608.jpg) Dimensions: 914 Shaft, dia. = 25mm, length = 514mm 944 Shaft, dia. = 26mm, length = 540mm 914 CV, dia. = 94mm, width = 31mm 944 CV, dia. = 100mm, width = 35mm |
| SirAndy |
Aug 9 2005, 12:52 AM
i believe the spline is different for those and they won't fit the 914 axle ... (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) Andy |
SirAndy Rear 5-Lug with 944 Parts, PART II Aug 6 2005, 06:01 PM
Travis Neff Is this per Clay's conversion post? Good info... Aug 6 2005, 06:11 PM
SirAndy <... Aug 7 2005, 12:40 PM
Racer Chris <... Aug 7 2005, 12:41 PM
Racer Chris Aug 7 2005, 12:42 PM
SirAndy ... Aug 7 2005, 07:20 PM
SirAndy UPDATE on the machining of the 914 shaft ...
her... Aug 7 2005, 07:23 PM
Gary Cool thread! Appreciate your sharing the info.... Aug 7 2005, 07:32 PM
Mueller wow...I have more hair than I thought Aug 7 2005, 07:46 PM
Dr Evil Aug 7 2005, 09:42 PM
seanery Andy,
I bet $5 it's from an 86 turbo, the... Aug 7 2005, 11:10 PM
V6914 Posted: Jun 14 2005, 04:31 AM
My running 914... Aug 8 2005, 12:25 AM
914Timo Hmmm..... It looks like 944 CVs are the same as 91... Aug 8 2005, 12:31 AM
Mueller Aug 8 2005, 08:40 AM
Aaron Cox will 69 911 hubs work? Aug 8 2005, 08:44 AM
ClayPerrine ... Aug 8 2005, 10:05 AM
SirAndy Aug 8 2005, 10:17 AM
ClayPerrine Added benefit. If the tranny ever does blow, you ... Aug 8 2005, 01:38 PM
914MF Do you have to machine both ends of the 914 axle s... Aug 8 2005, 02:27 PM
Mueller Aug 8 2005, 02:36 PM
SirAndy Aug 8 2005, 02:58 PM
914MF http://www.914world.com/bbs2/... Aug 8 2005, 03:32 PM
914Timo ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 04:33 PM |
