OT: My tow rig failed emissions! |
Eddie914 |
Aug 9 2005, 02:30 PM
Unregistered |
My tow rig failed emissions today in Seattle!
1983 Chevy 454 with a Quadra jet pushing a 27 ft motorhome chassis. It failed the Carbon Monoxide at idle test. HYDROCARBON (ppm) Cruise Limit: 220 Cruise Emissions: 33 Idle Limit: 220 Idle Emissions: 128 CARBON MONOXIDE (%) Cruise Limit: 1.2% Cruise Emissions: 0.75% Idle Limit: 1.2% Idle Emissions: 4.78% Unfortunately the idle mixture screws are sealed on this carburetor (for the time being). The air pump has been removed. What is interesting is that since I replaced the heads to rectify the badly worn valve seats the HC has gone substantially down and the CO has gone substantially down. Are the HC and CO inversely proportional? Should I lean it out? Should I richen it up? … or should I just shoot it? Thanks Eddie |
Brew |
Aug 9 2005, 04:43 PM
That's Captain Moron to you! Group: Members Posts: 391 Joined: 5-August 05 From: Colorado Springs Member No.: 4,546 |
Carbon monoxide is the incomplete burn of carbon molecules found in fuel.
Lean it out, or maybe advance the timing just a hair. Also, make sure your spark plugs/wires/distributor cap are all in excellent working order, and it doesnt hurt to run the vehicle HARD right before the testing is done. I usually run a higher grade of fuel for the test if there's any chance of it failing. Good luck! |
Lo-Fi Version | Time is now: 7th June 2024 - 09:49 AM |
