> oil light w/ turn signal?, befuddled...
vmills
post Aug 11 2005, 07:48 PM
My oil light is flashing. It has done this before, and it went out after a little driving. But it's back and it's not going away after a little driving, and I'm not sure how it works or why it's flashing. It also has some peculiar behavior I haven't noticed before...
Firstly, it starts flashing when I turn the ignition on, before I start the engine. Is this normal? It wasn't doing this before. I thought the oil light turned on when the oil pressure was too low? When the engine isn't running there is no oil pressure...is this normal for it to be flashing before the engine is on?
Secondly, if I use a turn signal while it's flashing, the oil light blinks at the same frequency as the turn signal. Same thing happens if I turn on the hazards. Is this normal? I've never noticed it before but it could've happened...
Also, is the car's oil situation so bad when it's flashing that I should stop driving it immediately? Can the light turn on steady (without flashing)? Oh, i'm so naive...thanks for any help
bd1308
post Aug 11 2005, 08:10 PM
Sir Post-a-lot
hmm....what *I* would do is actually to check the back of the guages.
i have a therory, but let me preface it by asking you a question....
i) if you turn the key to on, what happens to the oil light? does it blink or stay glowing.
ii) if you start the car and let it idle, does the oil light go out?
iii) have you checked the oil level...?
iv) Take a gander at the fuses....are any warped or corroded? replace offending fuses, please dont replace with bullets.....true story BTW.
v) what happens to the generator light during this whole situation (the B light)....does it do anything or just stay unlit?
vi) have you or a mechanic messed with the brake system lately?
feel free to answer in similar manner.
- Lo-Fi Version Time is now: 15th July 2025 - 02:51 AM
