> oil light w/ turn signal?, befuddled...
vmills
post Aug 11 2005, 07:48 PM
My oil light is flashing. It has done this before, and it went out after a little driving. But it's back and it's not going away after a little driving, and I'm not sure how it works or why it's flashing. It also has some peculiar behavior I haven't noticed before...
Firstly, it starts flashing when I turn the ignition on, before I start the engine. Is this normal? It wasn't doing this before. I thought the oil light turned on when the oil pressure was too low? When the engine isn't running there is no oil pressure...is this normal for it to be flashing before the engine is on?
Secondly, if I use a turn signal while it's flashing, the oil light blinks at the same frequency as the turn signal. Same thing happens if I turn on the hazards. Is this normal? I've never noticed it before but it could've happened...
Also, is the car's oil situation so bad when it's flashing that I should stop driving it immediately? Can the light turn on steady (without flashing)? Oh, i'm so naive...thanks for any help
GS9146Driver
post Aug 11 2005, 08:10 PM
The oil pressure light is illuminated by a ground provided by the oil pressure switch which has closed contacts when oil pressure is not present. You may have a wire grounded intermittantly. Sometimes weird things begin to happen as you described with the turn signals and hazards. To be really certain that it is wiring and you are not endangering the life of your engine, you could buy an inexpensive direct reading(tube connected) oil pressure gauge from your local auto parts store. Connect it up and run the engine, read the pressure- no pressure-shut it off!
I have the Haynes manuals and the electrical diagrams are very straight forward. BTW- what year is the car and what engine?
Geo (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
- Lo-Fi Version Time is now: 15th July 2025 - 03:40 AM
