> Fuel/ignition settings for best gas mileage??, up to 42° advance crazy??
Mueller
post Aug 15 2005, 05:10 PM
914 Freak!
I "borrowed" the quote below from aircooled.net
With the fuel prices going up and up, I figured that was the kick in the @ss I need to get my 914 up and running as a daily driver....since my fuel and ignition can be set however I want with my laptop, I figure I should optimize my little 1.8 for being as frugal with the petrol as it could be right now (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
It gets better! We give you the option of a vacuum advance on every unit except the basic model (single points are centrifugal only)! This means all you dual weber/dellorto guys can get another 4-5 mpg, AND the engine will pull harder off idle than ever before, and use less gas doing it (you can lessen the accellerator pump squirt, and idle jet size), while also running cooler! :-)
The vacuum advance is FULLY ADJUSTABLE with a 3/32" allen key in the vacuum port to adjust the vacuum diaphragm, and you set it according to vacuum measurements you get from your carb(s). This means it doesn't matter what carb(s) you have, and it also doesn't matter what cam you are running! While other guys are running 32 degrees of full advance, you will be cruising around at 42 degrees on the highway, which optimizes mileage! It's important to know that the 32 degree setting is fine for full throttle, but at part throttle (cruise) you can use 42 degrees. If you are only running 32, your timing is retarded 10 degrees from optimal! Retarded timing creates MORE HEAT. This means you run cooler and use less gas if you have a properly working vacuum advance (VW put it on all their engines for a reason).
All you need is a ported vacuum source ("ported" means the vacuum is coming from right above the throttle plate); do NOT run this to manifold or venturi vacuum!. Ported vacuum is 0 vacuum at idle, and 15-25" of vacuum at 3000 RPM and 1/8 - 1/2 throttle.
Mueller
post Aug 15 2005, 05:29 PM
914 Freak!
QUOTE (Cap'n Krusty @ Aug 15 2005, 04:23 PM)
QUOTE (bd1308 @ Aug 15 2005, 03:17 PM)
42 deg....is that even possible???
You DO realize that the vacuum advance on a bone stock 914 does, under certain conditions, go to 42 degrees, right? The mechanical advance goes to 28, or so, and the vacuum goes on from there. The Cap'n
I "thought" you mentioned that once John, I guess I was not too crazy afterall (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
i still say people can go max advance under a particular circumstance as long as there is no ping. nice to read your posting....
My wife starts working at the HD near your house in a few weeks, give me a good reason to come on over and check out your progress (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Mueller   Fuel/ignition settings for best gas mileage??   Aug 15 2005, 05:10 PM
jkeyzer   gas mileage, engine life... gas mileage, engine l...   Aug 15 2005, 05:14 PM
Dr. Roger   absolutely true. my dream car will have whatcha...   Aug 15 2005, 05:16 PM
bd1308   42 deg....is that even possible???   Aug 15 2005, 05:17 PM
Cap'n Krusty     Aug 15 2005, 05:23 PM
Mueller   <...   Aug 15 2005, 05:47 PM
bd1308     Aug 15 2005, 06:00 PM
bd1308   i was talking about vaccuum advance only..... i r...   Aug 15 2005, 06:01 PM
rhodyguy   for great fuel cost savings per week use public tr...   Aug 15 2005, 06:54 PM
cnavarro   Total advance aside, what target a/f ratio are you...   Aug 15 2005, 07:02 PM
Dr. Roger   13.8 to 14.2 to 1......... air to fuel ratio........   Aug 15 2005, 07:33 PM
Mueller   ...   Aug 15 2005, 07:53 PM
Jake Raby   I could write for days on this one- I won't ev...   Aug 15 2005, 07:56 PM
Andyrew   So what could you do to a sbc with an electronic d...   Aug 15 2005, 08:53 PM
scott thacher   28 + mpg at 80 + mph http://w...   Aug 16 2005, 12:16 AM
Jake Raby   I beat that in my 912E..... http...   Aug 16 2005, 12:25 AM
airsix   As always, the Cap'n is correct. On my PEFI I ...   Aug 16 2005, 10:21 AM
redshift
- Lo-Fi Version Time is now: 16th June 2024 - 07:26 PM
