| brant |
Aug 16 2005, 01:57 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,179 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
hi all.
forgive my ignorance. the time I had a big oil pump it was a melling with a flat cover that fit over it.. (you know the leaky one) so this go around I bought a different brand pump that comes with no cover and the instructions indicate that you re-use the flat cover. well guess what. I took the blower housing off and this 1975 2.0 does not have a flat cover. the pump is made into the cover and I won't be able to re-use this cover. what gives. Is my set up standard for a 75? do any years have a flat cover? do I have to get a melling instead? or produce my own cover? I have a 1.7 yet to tear up and I'm hoping it has a flat cover on its oil pump... but didn't get that far along yet. anyone care to shed some light? tia brant |
| Aaron Cox |
Aug 17 2005, 09:51 AM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
IIRC 35mm length.... not sure... M8's right? AA |
brant oil pump cover ? Aug 16 2005, 01:57 PM
Jake Raby Sounds like you have wither a Melling or Modified ... Aug 16 2005, 02:17 PM
brant Thanks again Jake.
and the pump I bought from my ... Aug 16 2005, 03:09 PM
Cap'n Krusty What's wrong with the pump you already have in... Aug 16 2005, 03:30 PM
brant Captain,
the chassis has a front mounted oil coo... Aug 16 2005, 03:56 PM
Aaron Cox Aug 16 2005, 04:00 PM
brant Aaron,
I think so.
Its hard to tell.
the motor w... Aug 16 2005, 04:07 PM
brant Jake,
if you see this again.
do I need longer st... Aug 16 2005, 09:50 PM
Aaron Cox Aug 16 2005, 09:52 PM
Jake Raby Yes you need longer studs... I have them on the st... Aug 16 2005, 09:53 PM
brant Jake,
couldn't you reply any faster... shees... Aug 16 2005, 10:00 PM
brant Ok...I'm stupid.
anybody know where on jake... Aug 17 2005, 08:40 AM
brant ?
bump...
I want to place my order but am not sur... Aug 17 2005, 01:47 PM
dmenche914 Never ever use the "flat" cover for the type I oil... Aug 17 2005, 03:53 PM
brant dmenche914,
do you know what pitch and length of... Aug 17 2005, 04:23 PM
Jake Raby 8mmX1.25X35mm
Dave is absolutely right about the ... Aug 17 2005, 06:20 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 12:46 AM |
