Clutch Tube reweld???, AA says to do it.... |
tracks914 |
Aug 18 2005, 02:59 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I find that I have to keep tightening my clutch every couple of weeks. In an AA catalogue, one of their little window box tips says that if this happens then you need to reweld your clutch tube.
Is this true? Where is the clutch tube located? tx |
GaroldShaffer |
Aug 18 2005, 09:21 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Just had this repair done on my car about month ago. No need to remove the shifter just pull the shifter boot cover off you should be able to see the tube, push in the clutch if the tube moves it has at least one broken weld, mine had the two in the tunnel and a crack at the firewall (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) I didn't do the repair, Brad Mayuer did (actual Michael did). I believe they did it with the engine still in the car. Good luck. (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) |
Lo-Fi Version | Time is now: 17th June 2024 - 05:37 AM |
