> learn something new everyday, and its making my head hurt
brer
post Aug 19 2005, 02:06 PM
So last night we were working on rotational motion and all i could think about was the crank in my motor and my car going around a corner..
anyone want to help explain this to me?
An object spinning at a constant speed has less acceleration at each consecutive point as you move further out from the center.
acceleration being related to the radius of the rotational orbit and the constant change in directional velocity.
Makes me car sick just thinking about it.
(IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif)
bondo
post Aug 19 2005, 03:37 PM
I'm confused by the spinning object situation...
If something is spinning at x RPM, every point on it is changing direction at the same rate. The points farther from the center are moving at a faster speed, but their direction is changing at the same rate as points close to the center. It seems to me that the outside points should have GREATER acceleration if you're looking at constant RPM.
This also makes sense in a real world sense as it's trickier to make large hign rpm rotational devices than small ones. Gyroscopes also put most of the mass on the outside. Hmm..
brer   learn something new everyday   Aug 19 2005, 02:06 PM
qa1142   http://www.914world.com/bbs2/htm...   Aug 19 2005, 02:08 PM
brer   http://www.914world.com/bbs2/h...   Aug 19 2005, 02:10 PM
ArtechnikA     Aug 19 2005, 02:36 PM
lapuwali   Acceleration isn't just a change in speed, it...   Aug 19 2005, 02:38 PM
brer   that was from my notes. He's about 5 seconds...   Aug 19 2005, 03:05 PM
brer   which is why doing 60 through a 20mph turn is diff...   Aug 19 2005, 03:08 PM
Howard     Aug 19 2005, 03:09 PM
Tom Perso   Sounds like someone is in a Dynamics class.... <...   Aug 19 2005, 03:13 PM
bondo   Acceleration is a change in velocity, and velocity...   Aug 19 2005, 03:26 PM
bondo   I'm confused by the spinning object situation....   Aug 19 2005, 03:37 PM
phantom914     Aug 19 2005, 03:46 PM
Sammy   as soon as i started reading the other replies it ...   Aug 19 2005, 03:52 PM
Dr. Roger     Aug 19 2005, 03:54 PM
bondo     Aug 19 2005, 05:07 PM
brer   the outlying mass of arms and legs have greater ve...   Aug 19 2005, 05:11 PM
Rotary'14   what if "D", "O", "G", spelled cat? Whoa,, now th...   Aug 19 2005, 05:13 PM
tdgray   OMG... Brain cramp... brain cramp ...   Aug 19 2005, 05:19 PM
rhodyguy   those playground merry-go-rounds spin much too qui...   Aug 19 2005, 05:20 PM
kwales   The correct answer is it all depends on your plane...   Aug 19 2005, 08:30 PM
brer   while studying today i found the math for it. for ...   Aug 20 2005, 10:01 PM
SirAndy     Aug 20 2005, 10:07 PM
- Lo-Fi Version Time is now: 3rd July 2025 - 11:31 PM
