groot |
Dis member ![]() ![]() ![]() Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 ![]() |
I'm headed to M-O this weekend to race. Anybody else going?
I'm trying out a few things and uncovered a problem or two in the process. For cooling, I'm running 2-3" ducts from the turn signal openings (one on each side)... I know many of you think it's not enough, but I'm willing to try it out before I run a huge duct. I also replaced by EGT senders with some Westach parts. I was checking to see if they worked and oh, my..... they read a lot higher than my other senders did. I'm guessing the old senders were not the right calibration to work with my Westach gage. I still have to do the alignment, I'm removing some camber to save weight.... (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Actually running a deflector in the middle may work well if you make some other deflectors to speed up the air on either side of the main deflector.
Lo-Fi Version | Time is now: 17th June 2024 - 08:32 AM |
