Clutch Tube reweld???, AA says to do it.... |
tracks914 |
Aug 18 2005, 02:59 PM
Canadian Member Group: Benefactors Posts: 2,083 Joined: 15-January 03 From: Timmins, Ontario, Canada Member No.: 153 Region Association: None |
I find that I have to keep tightening my clutch every couple of weeks. In an AA catalogue, one of their little window box tips says that if this happens then you need to reweld your clutch tube.
Is this true? Where is the clutch tube located? tx |
tracks914 |
Aug 22 2005, 05:19 PM
Not balls.....calculated risk. What you didn't see was the sheet metal shroud I had made and duct taped to the underside of the car, wrapped around underneath to shield the gas lines as I welded. No big deal then. The plate I used was heavy enough guage that it acted like a heat sink so the lines never got hot. BTW, I had a garden hose and a fire extinguisher parked nearby too. |
Lo-Fi Version | Time is now: 17th June 2024 - 05:32 AM |
