brake prop valve adusting, any experience doing this? |
Trekkor |
Aug 23 2005, 12:05 AM
I do things... Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
I still have the stock proportioning valve in the car.
I think the brakes favor the fronts a little too much. I smoke the fronts, never the rears. I'd like to put on some junk tires and see if I can get to the point where when I apply max brake pressure, the rears lock just after the fronts. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Anybody try this experiment? KT |
KenH |
Aug 23 2005, 03:12 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
Most 914s I know about have replaced the valve with the "T".
Bias was added by running agressive pads up front and the next lowest rate pad in the rear. Have run this combination with 2 914s without incident. If you want to play then add an adjustable valve. Not hard, but you have to make up new brake lines to connect it. Ken |
Lo-Fi Version | Time is now: 17th June 2024 - 01:57 AM |
