| GeorgeRud |
Aug 24 2005, 07:42 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,725 Joined: 27-July 05 From: Chicagoland Member No.: 4,482 Region Association: Upper MidWest |
Has anyone converted their instrument panel illumination lights to LEDs yet? They are being sold as upgrades and are supposed to make the instruments brighter (good for these older eyes). I know the 2 watt bulbs can be replaced with 4 watt bulbs, but I was warned by North Hollywood Speedometer not to do it as the extra heat generated will eventually fry the innards of your instrument. I like the idea of brighter instruments however.
| lapuwali |
Aug 25 2005, 09:45 PM
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
I'll bet that NH Speedo setup has quite a few LEDs in there. A lot more than 2, anyway. LEDs don't put out a lot of light compared to incandescents, and they only put out light in a narrow beam, not spherically. They use so little power and emit so little heat, however, that you can use a dozen of them in place of one bulb and end up with more light for less power. You need to rig up a little board with them mounted so they point in several directions to get a good spread of light.
LEDs also can't be dimmed using the normal means of just reducing the voltage, so you're dash light dimmer won't work. LEDs are either on or off. "Dimming" them involves flashing them fast enough you can't quite see the flashing. The duty cycle of the flashing will determine how bright it is. This doesn't take much circuitry to accomplish, but it's more than a simple rheostat and a bulb. The eye does not respond well to blue light, and things lit with that appear fuzzy to just about everyone. Green is a much better color to light something with, but green LEDs are quite a bit dimmer than blue leds. If you use an array of blue, red, and green LEDs, you end up with nearly white light (tends to be blue-shifted, since the blue LEDs are so bright). Amber LEDs also work pretty well for lighting. |
GeorgeRud LED Instrument Illumination Aug 24 2005, 07:42 PM
bd1308 yeah, some member's kid was doing it for extra... Aug 24 2005, 07:54 PM
swl Umm - isn't the whole point of the LED is that... Aug 24 2005, 07:56 PM
bondo I hear the top of the tach is a little dark.. Dr. ... Aug 24 2005, 08:00 PM
bd1308 this is true....
the light is pretty focused........ Aug 24 2005, 08:00 PM
bd1308 Aug 24 2005, 08:02 PM
mihai914 I bought a set of white and red LEDs for the clust... Aug 24 2005, 08:03 PM
Dr Evil Yup, all blue. I did mod my gauge with a third bun... Aug 24 2005, 09:50 PM
mrihop NH speedo did mine. I am VERY happy with the resu... Aug 25 2005, 12:24 AM
SM2270 Wow. That does look easy to see. What does somet... Aug 25 2005, 09:16 PM
SGB http://www.914world.com/bbs2/htm... Aug 25 2005, 09:33 PM
Brando The best way to get your gauges glowing... go with... Aug 25 2005, 09:54 PM
jonwatts No one has brought up case mods yet. You can get E... Aug 25 2005, 10:30 PM
jkeyzer ... Aug 25 2005, 10:39 PM
mrihop Fuzzy? Hard to read? My picture makes them look ... Aug 25 2005, 11:39 PM
JmuRiz Aug 26 2005, 08:09 AM
ewdysar I stuck with the stock bulbs when my gauges were a... Aug 26 2005, 11:41 AM
bd1308 who said they weren't dimmable????
i've p... Aug 26 2005, 11:58 AM
bondo Aug 26 2005, 12:42 PM
lapuwali Aug 26 2005, 12:53 PM
jkeyzer If I were doing this I would dim them with PWM in ... Aug 26 2005, 01:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 10:53 AM |
