pedal cluster roll pin, fixed or not? |
mightyohm |
Aug 26 2005, 12:39 AM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
Does anyone know for certain if the roll pins in the bronze bushing kits are any good or not? I read some time ago that they were having quality problems.
Maybe more helpful would be if someone has a pic of the Porsche roll pin vs. the Weltmeister pin. Any obvious differences? |
bondo |
Aug 26 2005, 11:27 AM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
We are talking about a pin about 3/16" diameter, that holds the clutch pedal to the rod that goes through the pedal cluster which has an arm on it that pulls the clutch pedal. The pin needs to withstand a few hundred pounds of shear force.. aluminum or brass isn't going to do it. A roll pin is nice as it holds itself in place, and the factory steel one does the job just fine. You could substutute a tight fitting piece of an appropriately sized drill bit, but then you would have to devise a way to hold it in place. Something like that may be necessary for some sort opf mega-clutch with insane pedal force, but not for anything near stock. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:02 AM |
