> LED Instrument Illumination
GeorgeRud
post Aug 24 2005, 07:42 PM
Has anyone converted their instrument panel illumination lights to LEDs yet? They are being sold as upgrades and are supposed to make the instruments brighter (good for these older eyes). I know the 2 watt bulbs can be replaced with 4 watt bulbs, but I was warned by North Hollywood Speedometer not to do it as the extra heat generated will eventually fry the innards of your instrument. I like the idea of brighter instruments however.
bondo
post Aug 26 2005, 12:42 PM
QUOTE (bd1308 @ Aug 26 2005, 10:58 AM)
who said they weren't dimmable????
i've played with LEDs for years....there as dimmable as a regular bulb.
They are indeed dimmable.. but say your LED needs 3 volts for full brightness.. half brightness will not be 1.5 volts, but something more like 2.8. So once you add the resistor to the LED so it gets 3 volts from the 13.8v system, you need to be able to drop that voltage to something like 12.5 volts. Now your stock variable reststor for the instrument lights is probably 10 ohms or so.. When compared to the resistor needed to give the LED 3 volts at 13.8, that's nothing. All this gets thrown out the window if the LED modules have an internal regulator (which they might). If that's the case they will be the same brightness from 15v all the way down to something like 3.2v, because the regulator will vary its resistance to keep the voltage to the LED itself at 3v.
GeorgeRud   LED Instrument Illumination   Aug 24 2005, 07:42 PM
bd1308   yeah, some member's kid was doing it for extra...   Aug 24 2005, 07:54 PM
swl   Umm - isn't the whole point of the LED is that...   Aug 24 2005, 07:56 PM
bondo   I hear the top of the tach is a little dark.. Dr. ...   Aug 24 2005, 08:00 PM
bd1308   this is true.... the light is pretty focused........   Aug 24 2005, 08:00 PM
bd1308     Aug 24 2005, 08:02 PM
mihai914   I bought a set of white and red LEDs for the clust...   Aug 24 2005, 08:03 PM
Dr Evil   Yup, all blue. I did mod my gauge with a third bun...   Aug 24 2005, 09:50 PM
mrihop   NH speedo did mine. I am VERY happy with the resu...   Aug 25 2005, 12:24 AM
SM2270   Wow. That does look easy to see. What does somet...   Aug 25 2005, 09:16 PM
SGB   http://www.914world.com/bbs2/htm...   Aug 25 2005, 09:33 PM
lapuwali   I'll bet that NH Speedo setup has quite a few ...   Aug 25 2005, 09:45 PM
Brando   The best way to get your gauges glowing... go with...   Aug 25 2005, 09:54 PM
jonwatts   No one has brought up case mods yet. You can get E...   Aug 25 2005, 10:30 PM
jkeyzer   ...   Aug 25 2005, 10:39 PM
mrihop   Fuzzy? Hard to read? My picture makes them look ...   Aug 25 2005, 11:39 PM
JmuRiz     Aug 26 2005, 08:09 AM
ewdysar   I stuck with the stock bulbs when my gauges were a...   Aug 26 2005, 11:41 AM
bd1308   who said they weren't dimmable???? i've p...   Aug 26 2005, 11:58 AM
bondo     Aug 26 2005, 12:42 PM
lapuwali     Aug 26 2005, 12:53 PM
jkeyzer   If I were doing this I would dim them with PWM in ...   Aug 26 2005, 01:01 PM
- Lo-Fi Version Time is now: 1st May 2026 - 10:56 AM
