Visual inspection and testing of FI trigger points, What are your methods |
echocanyons |
Aug 26 2005, 02:02 PM
Advanced Member Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California |
I have had a progressively worsening problem with part-full load bucking it seems to be worse when the engine is cold.
I have tested/replaced the TPS. Now I am leaning on the FI points being the culprit. How are these tested? What should I look for upon visual inspection? Any other causes for my symptoms? here is what I have gone through trying to nail this down: Ingition improperly set (mine is spot on to factory specs) Possible malfunctioning vac adv (mine seems to function with suction) Fuel pump/filter clog (my tank was recently acid bathed and has a new filter and a inline pressure gauge reads normal at idle and revs while sitting). |
redshift |
Aug 28 2005, 02:32 PM
Bless the Hell out of you! Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Everything was fresh, new, or rebuilt, except the actual relay. It failed, and worked in such a way, that you'd not hear the pump on-off-on-off-on-off....
You should see THOSE relays do the on-off dance. clickclickclickclickclickclickclick. M |
Lo-Fi Version | Time is now: 2nd June 2024 - 09:27 AM |
