| solex |
Aug 28 2005, 06:18 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Hello,
Have not posted in a while been busy but have made some progress on a few fronts. Today I removed my speedo to fix the odometer. I would like to replace the plastic lens with one made from glass, pelican does not stock these anymore can I simply get some cut from glass or does anyone have a source? Also, is there a simply way to increase the lumonisty of the guage bulbs? Thanks, Dan Attached image(s)
| bperry |
Aug 28 2005, 11:34 PM
Lurker ![]() ![]() Group: Members Posts: 477 Joined: 16-February 04 From: Dallas, Tx Member No.: 1,661 |
Hmmm. My '74 speedo lens is/was glass.
But years ago, 15+, I did replace the lens in my tach which was plastic. It was warped convave in and was causing the tach to stick by rubbing on the silver button in the middle. I called around to several art & glass supply shops asking if they could cut a circular piece of glass. Finally found an art supply shop that said they could. I brought in the tack and the plastic lens to their shop and watched them attempt to cut the glass. It was truely a sad sight. Their tool used a compass type device with a suction cup in the middle and a nicely marked and high precision adjuster. The girl could not figure out how to get from diameter to radius which is what the cutter measured in. After 2 attempts which created perfectly round glass but not even close to the right size. I asked if I could run the tool and she allowed me to. I measured the diameter and marked it on a piece of paper then folded the paper in half and used that to set the compass. (Metric, Standard, who cares.....) I then scored the glass, and snapped it with their plyers and in less than 5 minutes had my new glass for my tach. Cost me all of $2.00. [but that was 15 years ago] If you can find a place that can cut the glass, I'd go with glass over the plastic. There are different thicknesses of glass and you should be able to get close enough to work. That anti glare glass described in the previous post sounds great, thats what I go for now if I had to do it again. And if its a tiny bit loose, a tiny dab of silicone sealer will hold it in place. Good luck. --- bill |
solex Speedo Glass Lens Aug 28 2005, 06:18 PM
bd1308 1st off: polish the inside of the guage housing, t... Aug 28 2005, 06:23 PM
Tobra There is a plastic polish that is used for airplan... Aug 28 2005, 06:34 PM
bd1308 psssh....
take them the plastic one, and just hav... Aug 28 2005, 06:37 PM
markb I think the glass lenses are slightly thicker than... Aug 28 2005, 06:37 PM
solex I use brasso on my acrylic watches, and used it on... Aug 28 2005, 06:47 PM
eric914 I went to a stained glass shop; one where they sel... Aug 28 2005, 07:28 PM
bd1308 yeah get them to bevel the edges....that'll he... Aug 28 2005, 10:32 PM
bperry Oh, one other word of caution as you re-assemble y... Aug 28 2005, 11:43 PM
Tobra Also, if you are repainting, don't put it on t... Aug 29 2005, 02:26 AM
pfierb The plastic cleaner & scratch remover is called Pl... Aug 29 2005, 03:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 01:07 AM |
