> Any Luck With Single Carb
rickso71
post Aug 29 2005, 08:18 PM
I've seen the advice... dual carbs or FI... DON"T GO SINGLE CARB! I plan to return to FI, possibly over the winter, but unfortunately right now all I have is a single carb and it's not running very well and I want to drive the car for a while before winter.
Anyone have a single progressive carb setup that runs OK? Not looking for blistering acceleration just something driveable. My problem is giving gas off idle causes a stumble and I need to work the gas to be able to accelerate. Don't know if single carb can be driveable or if just something wrong with my setup. Have tried different settings of mixture.
The car is a '71 1.7L with Weber 32/36 DFEV.
morph
post Aug 29 2005, 10:19 PM
quality parts builder
you can make a single carb work on a 914.i drove for two years on one.you have to run rich to get it to work right with your motor.this is the reason why people recomend againts using one.YOU CAN MAKE A SINGLE CARB WORK.you just wont be doing your motor any favors in the long run or get anytype of performance/economy period,but you can make it run smoothly.i ran a dgav weber.make sure your ignition is all in order first.b4 you start on adjusting the carb.you may have to jet up to get it to work right.a single carb can get you by.till you get a better fuel system.
james
rickso71   Any Luck With Single Carb   Aug 29 2005, 08:18 PM
!   It's a continuous nightmare......   Aug 29 2005, 08:59 PM
eg914   I have been living with the same setup for the las...   Aug 29 2005, 09:03 PM
bd1308   it's a good setup.....well depends on your eng...   Aug 29 2005, 09:10 PM
URY914     Aug 29 2005, 09:22 PM
eg914   Mine is also a 1.7L. The single carb is a terribl...   Aug 29 2005, 09:28 PM
morphenspectra   you can make a single carb work on a 914.i drove f...   Aug 29 2005, 10:19 PM
!   Aw for Cryin' out loud....that carb was made f...   Aug 29 2005, 10:22 PM
bd1308   i dont care either way....i'm staying out of t...   Aug 29 2005, 11:37 PM
Mueller     Aug 29 2005, 11:55 PM
grantsfo   I ran a real great t4 Bus engine on a single carb....   Aug 30 2005, 12:03 AM
Dr. Roger   Hmmm, I ran a single 1 barrel weber in my 1.6 Ghia...   Aug 30 2005, 12:50 AM
Dr. Roger   Cold weather solution for the flat 4 engine. See...   Aug 30 2005, 01:01 AM
ArtechnikA   http://www.914world.com/bbs2/...   Aug 30 2005, 05:41 AM
rickso71   Thanks for the ideas and suggestions. I'm runn...   Aug 30 2005, 06:19 AM
jr91472   I have been running the single carb on my 1.8L for...   Aug 30 2005, 07:29 AM
!   <...   Aug 30 2005, 07:32 AM
morphenspectra   you may have your advance set up alittle to far,tr...   Aug 30 2005, 08:05 AM
bd1308   PP's tech article on carbs states to set the a...   Aug 30 2005, 08:38 AM
jr91472   http://...   Aug 30 2005, 11:36 AM
bd1308   are you talking about ME? YOU cool YOUR jets........   Aug 30 2005, 12:04 PM
Aaron Cox   is britt gonna cry?   Aug 30 2005, 12:11 PM
bd1308   no. I have a computer I need to put linux on. I e...   Aug 30 2005, 12:23 PM
jr91472   sorry I brought it up http://www.91...   Aug 30 2005, 12:26 PM
bd1308   pretty much man, some people think it works from r...   Aug 30 2005, 12:29 PM
markb   I had the pinto carb on Dad's car. It went lea...   Aug 30 2005, 12:35 PM
Aaron Cox     Aug 30 2005, 12:37 PM
Headrage   I had a Pinto carb on a car that I had and it work...   Aug 30 2005, 12:43 PM
markb   ...   Aug 30 2005, 12:46 PM
tdgray     Aug 30 2005, 01:11 PM
Aaron Cox   we need a britt dodd intervention...   Aug 30 2005, 01:39 PM
bd1308   but i didnt have the $$ to buy a new har...   Aug 30 2005, 03:33 PM
- Lo-Fi Version Time is now: 11th July 2025 - 08:46 AM
