Engine Cooling Flaps, fully closed/open position |
BMartin914 |
Sep 1 2005, 11:12 PM
||| Group: Members Posts: 1,408 Joined: 30-May 04 From: Oregon Member No.: 2,128 Region Association: Pacific Northwest |
I am putting the final touches on my engine after having it apart for some time. I can't recall which position the cooling flaps should be in for full closed when cold.
Should the thermostat wire be pulling on the flaps when cold and then expand to allow them to open (putting the attaching point in the upright position when warm) or does the wire pull the flaps open as it expands? Might sound like a dumb question to some, but I can't quite understand how they flow - hot vs. cold. (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) |
BMartin914 |
Sep 2 2005, 07:20 AM
The classic thread is helpful, but I agree it is a bit confusing.
I think that the most valuable tidbit I took from it is that the flaps are designed to be in the "full open" position if the wire were to break. So basically, the spring has no tension on it when hot and as it cools back down, the bellows pull the flaps closed. I think I have got it now. It also makes it a bit tough when you cannot see the flaps, only what is above the tin. |
Lo-Fi Version | Time is now: 10th June 2024 - 09:20 AM |
