Rear License Plate Light Wiring, Different for Early Bumpers |
Allan |
Sep 4 2005, 12:07 PM
Teenerless Weenie Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California |
Well I got the rear bumper on finally (Pics Coming) but I noticed that the wiring harness has 2 positives and a ground for the left light and a single positive and ground for the right. The early bumper I have just has 1 connection on each light. What is the proper way to hook them up? How do they ground? Through the bumper? Is the metal in the rubber pad?
Thanks for you prompt responses... |
SLITS |
Sep 4 2005, 04:09 PM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
If you have the early lights there are two... If you only see one: 1.) You are blind 2.) You are studing to be an engineer 3.) One is broken off....peel back the rubber to expose the assembly The problem with christening the Titanic is they used some cheap Brit Champange...wouldn't go for the good (at that time) French stuff...a bit of a rivalry you see...bloddy frogs anyhow. Now you know why it really sank (I suppose I could have reduced speed in the conditions, but I'm a teener driver (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) I would suggest mounting the B&S's on each wheel..direct power... |
Lo-Fi Version | Time is now: 8th June 2024 - 04:44 PM |
