| swood |
Aug 5 2003, 11:15 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,845 Joined: 6-February 03 From: Strong Beach Member No.: 251 Region Association: None |
Dry mocking up my T1 pump to the case and Web #73 cam and gear I observed the following:
.055" apparent clearance between oil pump shaft and cam gear. Is this enough? There is a void at the outer end of the gear post and gear of .68" that could be reduced via a press. Watcha think? |
Brad Roberts I must not be reading this correctly..
The oil pu... Aug 5 2003, 11:21 PM
Mueller Disclaimer: I do not know if this is correct or no... Aug 5 2003, 11:23 PM
Brad Roberts What was the main reason for running this pump ?? ... Aug 5 2003, 11:30 PM
swood Yeah, I'll get a pic up. I'm doing a full... Aug 6 2003, 11:35 AM
cgnj Ok here is my experience.
Nose of the pumps has t... Aug 6 2003, 02:54 PM
swood I got most of the milling done on the pump body, a... Aug 7 2003, 03:03 PM
swood There's 0.263" of tang meat in the cam gear. C... Aug 7 2003, 08:58 PM
swood Modified pump Aug 8 2003, 03:26 PM
swood Here the pump gear with drive tang is not indexed ... Aug 8 2003, 03:29 PM
swood almost ready to go Aug 8 2003, 03:30 PM
swood pump cover. no interferance on the outside of pump... Aug 8 2003, 03:31 PM![]() ![]() |
Lo-Fi Version | Time is now: 1st May 2026 - 05:45 AM |
