> Schadek (sp?) oil pump mod, B-you want the lurkers to chime, yeah?
swood
post Aug 5 2003, 11:15 PM
Dry mocking up my T1 pump to the case and Web #73 cam and gear I observed the following:
.055" apparent clearance between oil pump shaft and cam gear. Is this enough?
There is a void at the outer end of the gear post and gear of .68" that could be reduced via a press.
Watcha think?
Brad Roberts
post Aug 5 2003, 11:21 PM
914 Freak!
I must not be reading this correctly..
The oil pump shaft goes into the cam itself. Its may have .055 worth of "slop" if you twist the gear back and forth... but not .055 front to back.
Do you have a camera ?? this would be a neat pic.
B
- Lo-Fi Version Time is now: 1st May 2026 - 05:46 AM
