Rear wheel bearing...., squeek squeek squeek |
Gilbert914 |
Sep 15 2005, 01:45 AM
Newbie Group: Members Posts: 49 Joined: 24-August 05 From: London UK Member No.: 4,657 |
Hi All,
for those of you who helped and read my impeller woes, I fitted the woodruff key, installed the hub etc etc, got the engine back in and it's running well and has been for over half a tank of fuel (mileage unknown odometer not working). Thanks again for all the help & advice. Now...... my rear wheel bearing is squeeking, first i thought the caliper venting clearance may have been out or a siezed caliper, but on jacking up the car releasing the caliper, removing the disc and running the car the squeek still came from the wheel bearing, it's almost like it sounds 'dry' (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) I've seen a few threads on rear bearing replacement, it looks like a real pita to do, i'm tempted to get a shop to do it for me, but welcome any encouraging stories/tips for DIY replacement cheers guys |
Cap'n Krusty |
Sep 15 2005, 01:00 PM
I have top tell you that a squeek is atypical of a wheel bearing problem. Look elsewhere. Bearings "howl", or "rumble", they don't squeek. The noise appears under load, changes during changes in direction, and increases with speed. You would hardly hear it with wheel off the ground unless it were REALLY bad. The Cap'n
Lo-Fi Version | Time is now: 1st June 2024 - 02:07 PM |
