| 914zim |
Sep 21 2005, 05:57 PM
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Dudes:
Well, so far my clutch replacement seems to be holding up. I actually got a little driving in last weekend! I tried to take the 914 into work today and I noticed a slight burning burning smell, but I wasn't sure if it was from my car (lots of traffic). I only made it about 2 miles before the "GEN", "CAT" and "EGR" lights came on. I quickly turned around and headed for home. After work today, I found the belt wrapped around the pully on the engine. I've unwound it and am ready to replace it, but I was wondering how nasty of a job it is to replace. Wondering how to loosen the alternator in order to get the belt on. I did a quick search and didn't find anything right away. Can I get the replacement belt an any FLAPS? Any thoughts or comments from those who have done it would be appreciated! I was hoping to get this fixed quick and get back to driving before the snow starts flying! Thanks, Andy... |
| SLITS |
Sep 21 2005, 06:03 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Couple of skinned knuckles and a bit of swearing...not to bad
1. loosen 13mm pivot bolt from underneath 2. loosen hex head adjustor bolt thru engine tin (covered with the plastic thingys). I think its like a 5 mm hex 3. swing alt toward fan 4. Hard part is getting belt around fan as you can't see it 5. Belt goes around alt pulley (22 mm wrench to turn it) to make it easier. 6. Tension by pulling on alt thru other hole in engine tin (other hole covered with plastic thingy) 7. Tighten hex bolt 8. Tighten 13 mm under car 9. start engine and go |
914zim Replacing alternator belt Sep 21 2005, 05:57 PM
Dave_Darling Get a replacement at most FLAPS, or at your favori... Sep 21 2005, 06:00 PM
brp914 If you're '76 has air injection its a p.i.... Sep 21 2005, 06:58 PM
Cap'n Krusty 10mm x 965 mm, in case you're wondering ......... Sep 21 2005, 07:41 PM
914zim Thank you, Gentlemen!
I'll give it a try a... Sep 22 2005, 05:51 AM
ClayPerrine Make sure that you do what the Cap'n said. I ... Sep 22 2005, 09:22 AM
type47 ohh, Clay, you're mean http://w... Sep 22 2005, 10:43 AM
tdgray Probably find that water pump on the shelf with mu... Sep 22 2005, 11:00 AM
meares i need some muffler bearings too!!!... Sep 22 2005, 11:44 AM
SLITS Sep 22 2005, 12:09 PM
914zim Hey guys:
I just come out of the garage after taki... Sep 22 2005, 06:46 PM
Dave_Darling Yup, you've got it! Remove the pulley and... Sep 22 2005, 08:26 PM
914zim Cool! Thanks Dave! Sep 23 2005, 05:56 AM
Coolhandgoose Just got a 72 914. Belt snapped and I found this t... Aug 17 2023, 09:58 AM
iankarr Watch from 15:00 on…
https://youtu.be/7nyAJYLk2m... Aug 17 2023, 10:14 AM
Mikey914 Ill PM you the latest. Aug 17 2023, 11:15 AM
Shivers I’ve done it a few times in the car from the dri... Aug 17 2023, 11:46 AM
Jezibel :WTF: Hey gents, my alternator V-belt is a bit lo... Feb 14 2024, 12:59 PM
GregAmy Soooo, do I also have to loosen the other (bottom)... Feb 14 2024, 01:32 PM![]() ![]() |
Lo-Fi Version | Time is now: 11th August 2026 - 02:11 AM |
