Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Hi all
I recently picked up a 74 2.0. This car has not run in 20 years. I pulled the gas tank and fuel pump which was a mess. I changed the oil and I pulled the plugs. The compression is even on all 4 at 70 lbs. I know this is quite low. Is this to be expected? Should I try to get it started before doing another compression test or should I just resign myself that this motor must be rebuilt. I does have 88K on it. Thanks Mark |
Bartlett 914 |
Hi Mark
No I wasn't holding the throttle down. I will try that. The battery is also begining to get a little weak. I was never able to get the oil lamp off. Mark |
Lo-Fi Version | Time is now: 15th July 2025 - 11:27 AM |
