Bartlett 914 |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,218 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest ![]() |
Hi all
I recently picked up a 74 2.0. This car has not run in 20 years. I pulled the gas tank and fuel pump which was a mess. I changed the oil and I pulled the plugs. The compression is even on all 4 at 70 lbs. I know this is quite low. Is this to be expected? Should I try to get it started before doing another compression test or should I just resign myself that this motor must be rebuilt. I does have 88K on it. Thanks Mark |
Bleyseng |
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,036 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest ![]() |
wedge the TB open while you turn the motor over lots of rpms. A fresh battery helps.
Try a third test by squirting a tad of oil in each cylinder before testing and see if it goes up. (IMG:http://www.914world.com/bbs2/html/emoticons/monkeydance.gif) |
Lo-Fi Version | Time is now: 15th July 2025 - 11:19 AM |
