> Karl's Project Update, Clear here for the latest
Qarl
post Jul 25 2003, 08:07 PM
Shriveled member
Okay... I decided to start a Gint-like thread and just post progress instead of starting a new subject each time I do something neat.
Latest project.... Pedal cluster rebuild.
This is really VERY easy to do.
I had the pieces powder coated. Installed new bushings. Cleaned up everything and reassembled.
I'm also installing AJ billet pedals (I've got the billet gas pedal too).
Qarl
post Aug 8 2003, 09:41 PM
Shriveled member
Believe it or not, the triple gauge is the lightest of the three. The housing is an aluminum stamping instead of the pot metal.
Hey.. I've got them mounted in the plastic gauge panel from the '75 car to save some weight... ha!
I picked up a set of fiberglass front and rear GT hood replicas... the car is getting lighter and lighter...
Steel flares will add some weight....
Fiberglass bumpers, rockers, front and rear hood will save a bunch of weight.
I removed all of the tar, most of the seam sealer, the rear firewall insulation, and the engine firewall pad. Quite a bit of weight in total here.
What does a stocker 914 weigh? 2200 lbs or so? I'll probably come close to the original weight after it all evens out. Engine is heavier, flares are heavier, and bigger wheels and tires are slightly heavier.
Hoods, rockers, bumpers, and insulation reduce a lot.
Oops, I forgot about the chassis stiffening stuff... okay so I may be a little heavier!
Qarl   Karl's Project Update   Jul 25 2003, 08:07 PM
tahoward   Mental note to self: Must have billet pedals! ...   Jul 25 2003, 08:09 PM
Qarl   Also had the light buckets powder coated... althou...   Jul 25 2003, 08:09 PM
ein 6er   did you plate the hardware on the cluster yourself...   Jul 25 2003, 08:12 PM
Qarl   Cluster hardware cleaned up very nice to look new....   Jul 25 2003, 08:13 PM
rhodyguy   nice karl. with the influx of parts i take it your...   Jul 25 2003, 08:17 PM
Qarl   Unfortunately... not much work on the body other t...   Jul 25 2003, 08:23 PM
vortrex   so when is your targeted completion date? it...   Jul 25 2003, 08:33 PM
Brad Roberts   Do not let Karl fool you. Not all pedal assemblies...   Jul 25 2003, 08:46 PM
Qarl   Dumping money is right... :bootyshake: I am to...   Jul 25 2003, 08:55 PM
Qarl   Oh yeah... the roll pin was a BITCH. I drilled ...   Jul 25 2003, 08:58 PM
Curvie Roadlover   Karl, I have a question for you. Do you think that...   Jul 25 2003, 09:05 PM
Qarl   This car will NOT be a daily driver, but a weekend...   Jul 25 2003, 09:38 PM
Britain Smith   Nice work...I love it when people put the effort i...   Jul 25 2003, 09:50 PM
Qarl   Housing was powdercoated in gloss black Fan was b...   Jul 25 2003, 10:01 PM
URY914   Karl, You need a CPM schedule of your project. I d...   Jul 25 2003, 10:04 PM
Qarl   Thanks for the info Paul... this coming from someo...   Jul 25 2003, 10:13 PM
Andyrew   Karl that is going to look soooo cool. I cant wait...   Jul 25 2003, 10:48 PM
Mueller   Karl, It's great to see progress like this :...   Jul 25 2003, 10:56 PM
Qarl   Mueller... Yes the lower valve cover ribs were ma...   Jul 25 2003, 10:59 PM
shoguneagle   I have been watching your project with keen intere...   Jul 26 2003, 02:21 AM
URY914   Steve, Karl hasn't been working on his car for...   Jul 26 2003, 04:43 AM
Qarl   Yes... Paul's had his car for 24 years and it ...   Jul 26 2003, 09:33 AM
Bleyseng   Karl, everything is lookin great! On the tran...   Jul 26 2003, 11:03 AM
Qarl   European Racing Headers came in today... They look...   Jul 31 2003, 07:29 PM
Qarl   Hmmm... I think I'm gonna like this exhaust se...   Jul 31 2003, 07:30 PM
Scott Carlberg   Karl, what type of mufflers are those in the las...   Jul 31 2003, 11:07 PM
Qarl   Mufflers.... click here... http://www.914world.co...   Jul 31 2003, 11:10 PM
maf914   Karl, Everything is looking good! Where are ...   Aug 1 2003, 06:57 AM
Van914   You can also get these wheels. They are 15 X 6.5 a...   Aug 1 2003, 07:39 AM
Qarl   I like my wheels! I don't need minilites...   Aug 1 2003, 08:26 AM
seanery   Karl, You'll like the sterling finish. It loo...   Aug 1 2003, 08:29 AM
Aaron Cox   mufflers look a little rice to me! jk man. nic...   Aug 1 2003, 09:36 AM
Qarl   Engine Dressing...   Aug 2 2003, 01:57 PM
URY914   Paul, Is this going to be a work of art or a car? ...   Aug 2 2003, 06:09 PM
Curvie Roadlover   You're gonna need some velvet ropes to put aro...   Aug 2 2003, 08:43 PM
Qarl   Engine is 99% done... just need some pulley parts ...   Aug 8 2003, 05:31 PM
Qarl   Gauges are done...   Aug 8 2003, 05:32 PM
seanery   great looking gauges!   Aug 8 2003, 06:26 PM
Mueller   Karl, I think you'd have a few people interes...   Aug 8 2003, 07:47 PM
iansale   Karl, Where did you get the bezels for your gauges...   Aug 8 2003, 07:57 PM
Qarl   Palo Alto Speedometer installed them... http://ww...   Aug 8 2003, 09:03 PM
URY914   Real pretty, Karl. But they look heavy. :lol: :r...   Aug 8 2003, 09:32 PM
Qarl   Believe it or not, the triple gauge is the lightes...   Aug 8 2003, 09:41 PM
URY914   From the list of things you've done, I would s...   Aug 8 2003, 09:47 PM
Qarl   finished replating the hardware for the front ligh...   Aug 24 2003, 06:24 PM
Qarl   Gathered the rear suspension stuff...   Aug 24 2003, 06:24 PM
Qarl   And the front...   Aug 24 2003, 06:25 PM
Qarl   started stripping the rear trailing arms...   Aug 24 2003, 06:26 PM
Aaron Cox   bilsteins on the front? why not koni's?   Aug 24 2003, 06:28 PM
Qarl   Blisteins all round to go with these...   Aug 24 2003, 06:40 PM
ChrisReale   Pretty sweet karl. What Sway Bar are you gunna use...   Aug 24 2003, 07:03 PM
Qarl   Smart Racing bar. I locate the through-holes for ...   Aug 24 2003, 07:05 PM
URY914   So what's up with boxing the trailing arms? Ar...   Aug 24 2003, 07:10 PM
ChrisReale   Cool, what size?   Aug 24 2003, 07:11 PM
Aaron Cox   cool, bilstein strut assembly's.... :woohoo: -...   Aug 24 2003, 07:18 PM
Qarl   I have the arm reinforcing kits. Still debating o...   Aug 24 2003, 07:30 PM
redshift   Karl, do you have an extra injected longblock? w...   Aug 24 2003, 07:35 PM
Brad Roberts   Awesome Karl. Flat out awesome. I really get a kic...   Aug 25 2003, 12:42 AM
Andyrew
  Aug 25 2003, 01:30 AM
dbelleperc   Karl, very nice. :clap::clap:. Have you thought on...   Aug 25 2003, 04:05 AM
Brad Roberts   Timo, We purchase that kit from Clewitt engineer...   Aug 25 2003, 09:12 AM
fiid   I second what Brad says about doing it right. Doi...   Aug 25 2003, 09:57 AM
Qarl   I've got a set of period NOS Cibie Z-beam head...   Aug 25 2003, 12:15 PM
dbelleperc   Sorry when I was going to post the link is when th...   Aug 26 2003, 12:47 AM
Qarl   Been busy... Beed blasted the brake shields, A-ar...   Sep 2 2003, 09:59 PM
seanery   are you really gonna use the dust shields?   Sep 2 2003, 10:05 PM
scotty   Karl, your car is going to be too clean to drive...   Sep 2 2003, 11:14 PM
Brad Roberts   Karl.. to reach great Anal heights you must use a ...   Sep 3 2003, 12:01 AM
rhodyguy   karl, scotty was reading my mind. better save some...   Sep 3 2003, 05:30 AM
maf914   Karl and Brad, Karl, I remember from a previous ...   Sep 3 2003, 08:15 AM
Qarl   Early 911 5-bolt hubs Early 911 stub axles 4-bolt...   Sep 3 2003, 08:30 AM
maf914   Karl, Thanks. I wonder how hard it is to find Spo...   Sep 3 2003, 11:01 AM
Qarl   There are a couple of different variations on the ...   Sep 3 2003, 11:26 AM
Brad Roberts   You can run this setup with the regular 901/915 c...   Sep 3 2003, 12:14 PM
boxstr   Karl I was under the impression that the dust cove...   Sep 3 2003, 07:48 PM
echocanyons   I have the same rear setup why are you using rear ...   Sep 3 2003, 09:29 PM
Qarl   The early 911 (69-71) hubs use the same wheel bear...   Sep 3 2003, 09:34 PM
Qarl   Umm... Craig... you're probably right. I didn...   Sep 3 2003, 09:42 PM
Qarl   Okay... today's progress. 1:00 AM - couldn...   Sep 3 2003, 09:46 PM
Bleyseng   Those A arms look like prime targets for blasting,...   Sep 3 2003, 10:05 PM
Qarl   Yes... blasting tomorrow night. Too f-ing humid t...   Sep 3 2003, 10:06 PM
maf914   Too humid in the garage? Gee, I thought you were ...   Sep 4 2003, 07:10 AM
Qarl   Tank and parts came back from the powder coater to...   Sep 17 2003, 08:14 PM
Qarl   wysiwyg   Sep 17 2003, 08:14 PM
seanery   nice karl!   Sep 17 2003, 08:15 PM
echocanyons   Nice work! Theyre real purty!   Sep 17 2003, 08:18 PM
Eric Taylor   Very Nice Karl! Can't wait to see the fini...   Sep 17 2003, 10:09 PM
Brad Roberts   Cool. Looks like we are traveling the same paths.....   Sep 18 2003, 01:13 AM
Qarl   Okay... spent about an hour stripping the front su...   Sep 19 2003, 10:17 PM
Qarl   r434r   Sep 19 2003, 10:18 PM
Brad Roberts   I had my hubs beed blasted and EVERYTHING powder c...   Sep 20 2003, 01:22 AM
redshift     Sep 20 2003, 07:59 AM
maf914   Miles, If you're going to be on Wilmington Is...   Sep 20 2003, 08:43 AM
Qarl   Got Mueller's needle bearing installed on the ...   Sep 20 2003, 02:45 PM
Nemo914   Karl, Just spent the last 30 minutes reading thro...   Sep 20 2003, 03:22 PM
Qarl   Busy day... Finished installing the NOS Cibie hea...   Sep 20 2003, 11:44 PM
Qarl   Installed the ERP bump steer kit on the tie rods.   Sep 20 2003, 11:45 PM
Brad Roberts   You are going to hate yourself. You dont need that...   Sep 21 2003, 05:12 AM
Qarl   AAhhhh... what you are looking at is the result of...   Sep 21 2003, 09:14 AM
- Lo-Fi Version Time is now: 14th March 2026 - 07:08 AM
