> sandblaster, Seeking advice
turtleman
post Sep 27 2005, 07:21 PM
I am looking for sandblasting equipment to do small parts and spot repair.
Can any of you provide references for equipment you have seen or used?
What type system works better than others?
What medium works best for removing rust and paint without destroying surface?
GCW
Qarl
post Sep 27 2005, 07:48 PM
Shriveled member
Also... if you have a compressor driven blaster (most are), make sure your compressor is up to snuff. Little 5 gallon compressors won't cut it. YOu need to look at air flow rate, pressure, etc. Otherwise you'll find yourself blasting in small increments waiting for the pressure to build back up.
Search the forums here. It was discussed a couple of years ago.
- Lo-Fi Version Time is now: 16th June 2024 - 09:57 PM
