| Air_Cooled_Nut |
Oct 1 2005, 12:47 AM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
The AAR is stuck open on my 2.0L. In fact, when I connect it to the power source it pops the fuel pump fuse (25A) (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) I put a clamp on the hose so now I have to feather the throttle at stops until the engine is warmed up. Obviously, if I take the clamp off then the engine will idle really fast once op temp is reached.
I found a "spare" unit but it, too, is stuck open. Why can't they stick closed? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) So, what is there to replace it? I tried the 914 on-line part stores no no avail. AA was a PITA to "flip" thru their on-line catalog (yeah...whatever) and I get bored and gave up looking thru it. The device looks exactly like the unit I had on my previous Type 3 automatic -- which served the same function and was powered by the coil. So I got to thinking, the other units out there, for cars like water-cooled VW engines, use a similar device, just a little more aerodynamic looking (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Would one of those (less expensive) units work? Can someone point me to a place that does sell AAR's for our cars (not a "I think such-n-such sells them")? What have others done to fix or replace their failing units? Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
| Air_Cooled_Nut |
Oct 1 2005, 01:08 AM
Well, I'll see about busting open the 'replacement' unit that came with the car and fiddling with that. I did squirt PB Blaster in it and washed it around but no luck (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) One web site said to pop it in a vice and pry back the body to get to the innards for fixing it. I guess we'll see (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Air_Cooled_Nut Aux. air regulator woes. Oct 1 2005, 12:47 AM
redshift N L A
Some guy who lives in one of those unnamed ... Oct 1 2005, 12:52 AM
Air_Cooled_Nut Yeah, I know engine heat will do it as well. I wo... Oct 1 2005, 01:06 AM
Hammy don't have an answer but
what's this AAR..... Oct 1 2005, 01:10 AM
Dave_Darling Auxiliary Air Regulator. It lets air bypass the (... Oct 1 2005, 01:33 AM
type47 sounds like you have a D-jet. maybe you could look... Oct 1 2005, 06:30 AM
brp914 ![]() ![]() |
Lo-Fi Version | Time is now: 10th November 2026 - 05:05 AM |
