| Air_Cooled_Nut |
Oct 1 2005, 12:47 AM
914 Ronin - 914 owner who lost his 914club.com ![]() ![]() ![]() Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
The AAR is stuck open on my 2.0L. In fact, when I connect it to the power source it pops the fuel pump fuse (25A) (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) I put a clamp on the hose so now I have to feather the throttle at stops until the engine is warmed up. Obviously, if I take the clamp off then the engine will idle really fast once op temp is reached.
I found a "spare" unit but it, too, is stuck open. Why can't they stick closed? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) So, what is there to replace it? I tried the 914 on-line part stores no no avail. AA was a PITA to "flip" thru their on-line catalog (yeah...whatever) and I get bored and gave up looking thru it. The device looks exactly like the unit I had on my previous Type 3 automatic -- which served the same function and was powered by the coil. So I got to thinking, the other units out there, for cars like water-cooled VW engines, use a similar device, just a little more aerodynamic looking (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Would one of those (less expensive) units work? Can someone point me to a place that does sell AAR's for our cars (not a "I think such-n-such sells them")? What have others done to fix or replace their failing units? Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif) |
| Air_Cooled_Nut |
Oct 2 2005, 01:54 PM
Adjusting/retaining spring screw. In the setting shown, the spring will open more quickly. If the spring is adjusted to the opposite side of the slot, it will open more slowly.
Air_Cooled_Nut Aux. air regulator woes. Oct 1 2005, 12:47 AM
redshift N L A
Some guy who lives in one of those unnamed ... Oct 1 2005, 12:52 AM
Air_Cooled_Nut Yeah, I know engine heat will do it as well. I wo... Oct 1 2005, 01:06 AM
Air_Cooled_Nut Well, I'll see about busting open the 'rep... Oct 1 2005, 01:08 AM
Hammy don't have an answer but
what's this AAR..... Oct 1 2005, 01:10 AM
Dave_Darling Auxiliary Air Regulator. It lets air bypass the (... Oct 1 2005, 01:33 AM
type47 sounds like you have a D-jet. maybe you could look... Oct 1 2005, 06:30 AM
brp914 ![]() ![]() |
Lo-Fi Version | Time is now: 10th November 2026 - 05:05 AM |
