> Aux. air regulator woes., Engine unit dead, replacement too!
Air_Cooled_Nut
post Oct 1 2005, 12:47 AM
914 Ronin - 914 owner who lost his 914club.com
The AAR is stuck open on my 2.0L. In fact, when I connect it to the power source it pops the fuel pump fuse (25A) (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) I put a clamp on the hose so now I have to feather the throttle at stops until the engine is warmed up. Obviously, if I take the clamp off then the engine will idle really fast once op temp is reached.
I found a "spare" unit but it, too, is stuck open. Why can't they stick closed? (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) So, what is there to replace it? I tried the 914 on-line part stores no no avail. AA was a PITA to "flip" thru their on-line catalog (yeah...whatever) and I get bored and gave up looking thru it. The device looks exactly like the unit I had on my previous Type 3 automatic -- which served the same function and was powered by the coil. So I got to thinking, the other units out there, for cars like water-cooled VW engines, use a similar device, just a little more aerodynamic looking (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Would one of those (less expensive) units work? Can someone point me to a place that does sell AAR's for our cars (not a "I think such-n-such sells them")? What have others done to fix or replace their failing units?
Thanks (IMG:http://www.914world.com/bbs2/html/emoticons/beer.gif)
Air_Cooled_Nut
post Oct 2 2005, 01:54 PM
For my application I removed the ceramic cup, fiber washer and pigtail. Just a picture to show how it looks. To remove the ceramic cup the two rivets on the bottom of the AAR housing need to be drilled out.
Air_Cooled_Nut   Aux. air regulator woes.   Oct 1 2005, 12:47 AM
redshift   N L A Some guy who lives in one of those unnamed ...   Oct 1 2005, 12:52 AM
Air_Cooled_Nut   Yeah, I know engine heat will do it as well. I wo...   Oct 1 2005, 01:06 AM
Air_Cooled_Nut   Well, I'll see about busting open the 'rep...   Oct 1 2005, 01:08 AM
Hammy   don't have an answer but what's this AAR.....   Oct 1 2005, 01:10 AM
Dave_Darling   Auxiliary Air Regulator. It lets air bypass the (...   Oct 1 2005, 01:33 AM
type47   sounds like you have a D-jet. maybe you could look...   Oct 1 2005, 06:30 AM
brp914     Oct 1 2005, 09:48 AM
bd1308   plastic connectors and wires are available from Be...   Oct 1 2005, 10:44 AM
Air_Cooled_Nut   Thanks guys, and DD for a way to electrically test...   Oct 1 2005, 11:11 AM
redshift   http://www.914world.com/bbs2/htm...   Oct 2 2005, 01:53 PM
Air_Cooled_Nut   The bimetalic spring is easily removed and doesn...   Oct 2 2005, 01:53 PM
Air_Cooled_Nut   Adjusting/retaining spring screw. In the setting ...   Oct 2 2005, 01:54 PM
Air_Cooled_Nut   I removed the ceramic cup and bits then put the to...   Oct 2 2005, 01:55 PM
jsteele22   Cool pics ! It would be great ot see a galler...   Oct 2 2005, 02:04 PM
Air_Cooled_Nut   Just came back from a test run -- failure
- Lo-Fi Version Time is now: 10th November 2026 - 05:05 AM
