slugmika |
Member ![]() ![]() Group: Members Posts: 208 Joined: 19-February 03 From: Finland Member No.: 318 ![]() |
I'am going to raise my rear suspension pick up points and would like to know what should be the ride height?
I found that front shoud be 108mm from torsion bar center to spindle center. What is Porsches recomendation? I know that some of you have raised pick up points, have you used the factorys specs or what. How much have you raised those? And finally, is there any poin to make the stock kind of trailing arms? I have allready made a jig with stock trailing arm dimensions. Those would use stock bearing hub but otherwise made of tube. We would use uniball's rather than stock kind of bushings. Car is now on a table and it would be easy to make allmost anything, so if you have good ideas feel free to share Thanks Mika |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
thanks for the explanation...I was thinking pretty much in just one dimension (going straight and compressing the suspension)... actually, it was even less so, I was mostly thinking of the swinging action while the car is static....gotta learn how to read and buy some books (IMG:http://www.914world.com/bbs2/html/emoticons/clap.gif) |
Lo-Fi Version | Time is now: 13th June 2024 - 02:02 AM |
