pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,643 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
Any objections to running heavey copper lines with silver solder...It works great on refrigeration lines, lasts for years under great pressure and vibration....any objections
914GT |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region ![]() |
It would probably work OK if you used bronze vibration isolators at each end of the lines, and refrigeration-quality tubing. The isolators are used in commercial systems to connect the compressor to the refrigerant lines and prevent work-hardening of the tubing. But after you add up all the costs you might be better off going with hoses and approved fittings.
Lo-Fi Version | Time is now: 20th June 2024 - 06:21 PM |
