> Anyone here with CIS FI in a 914, six cylinder engine of course..
DougC
post Oct 6 2005, 12:37 PM
I have a couple of CIS specific questions and was wondering if anyone on the list might be able to help?
Doug C
DougC
post Oct 10 2005, 02:31 PM
Is that true even if the PO by-passed the fuel pump relay because he was using carbs? The reason I ask is because I actually pulled the FP relay and turned on the key...could still hear the FP running until I turn the key all the way to the final start position, at which point I no longer hear it (in any situation).
Sound the same weather there is a relay installed or not. BTW, thanks again guys.
Doug C
DougC   Anyone here with CIS FI in a 914   Oct 6 2005, 12:37 PM
ejm   http://www.914world.com/bbs2/h...   Oct 6 2005, 01:03 PM
DougC   First is a question about the wiring if you can he...   Oct 6 2005, 01:35 PM
Cap'n Krusty   Brown wires are ground. Might help if you tell us...   Oct 6 2005, 01:44 PM
ejm   WUR = warm up regulator... has fuel lines running ...   Oct 6 2005, 01:50 PM
DougC   2.7 from a '77 911s. This wire is brown with b...   Oct 6 2005, 01:58 PM
lapuwali   The WUR is a box that's perched on the top of ...   Oct 6 2005, 02:05 PM
DougC   OK, guys I'm getting confused trying to learn ...   Oct 6 2005, 02:28 PM
lapuwali     Oct 6 2005, 03:40 PM
DougC   Brown/black wire connects first to the WUR (mounte...   Oct 6 2005, 03:52 PM
Cap'n Krusty   Call me. I have the book open in front of me. 80...   Oct 6 2005, 06:31 PM
DougC   Cap'n I didn't get your message til after ...   Oct 10 2005, 01:08 PM
lapuwali   The 2.7 CIS is "basic" CIS. It requires almost no...   Oct 10 2005, 02:04 PM
Cap'n Krusty     Oct 10 2005, 02:13 PM
DougC   I can definately hear the fuel pump running.. Is t...   Oct 10 2005, 02:17 PM
Cap'n Krusty   ...   Oct 10 2005, 02:19 PM
lapuwali   If the fuel pump is running, the relay is fine. R...   Oct 10 2005, 02:23 PM
DougC   Is that true even if the PO by-passed the fuel pum...   Oct 10 2005, 02:31 PM
Root_Werks   You can also run the motor without the electrical ...   Oct 10 2005, 02:31 PM
lapuwali
- Lo-Fi Version Time is now: 8th July 2025 - 06:40 PM
