Help w/ 2L throttle cable link |
dlo914 |
Oct 13 2005, 12:55 AM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
nearing the end of my 914 reassembly i came upon the the throttle cable. i cant seem to find a way to connect it to the throttle lever. Went through the Haynes and nadda. Could someone post a picture of their throttle lever connected to the throttle cable? Thanks in advance (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
Dave_Darling |
Oct 13 2005, 12:01 PM
Those red wires look kinda like the ones that supply power to most of the car. They'd go on the (+) battery terminal--or rather, on the bolt on the terminal clamp.
You can't find the (+) terminal on the battery? Umm, that's a bit messed up! Aren't there a couple of metal posts sticking up out of the top of the thing? One should have a "+" by it, the other a "-". The two wires from the fuel pump should feed into the main wiring harness. From there, the brown one goes to the multiple ground point under the relay board (unless your car is a 75+, in which case I think the ground is up front), and the black/red (black with red stripe, the power wire) should go to the relay board, where one of the relays controls if it gets power or not. Looks like your car has been hacked on, though. Carb conversion? --DD |
Lo-Fi Version | Time is now: 1st June 2024 - 02:05 PM |
