Sealing Trunk/Tail lights, Got er done! |
ThinAir |
Oct 15 2005, 06:09 PM
Best friends Group: Members Posts: 2,543 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
I knew my rear trunk had leaks and I suspected the tail light assemblies since these are often the problem. The October 2005 edition of Excellence has a mention on page 172 of a product called "Dum-Dum" that is meant for sealing such things. I checked at my local Napa and at first they had no clue what this was. Then one of the "old guys" wandered by and knew that it was a generic name for a type of product. It turns out that the actual stuff is actually called "3M Strip-Calk". You get 60 feet of it for about $15. Here's a picture of it in the box.
Attached image(s) |
ThinAir |
Oct 15 2005, 06:16 PM
When I took off the bracket, here's what I found. Not only was there no seal under the bracket, but there were extra holes. One of the holes was not even completely covered by the bracket backing piece. I find it amazing what the PO did on this car! At least a little bit of Strip-Calk under the bracket backing plate fixed it up just fine. No more wet trunk!
Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 11:05 PM |
