> Charging Opima Red Top, Is there a trick I should know?
vesnyder
post Oct 17 2005, 06:24 AM
My year old Optima Red Top battery lost it's charge and I am trying to figure out a way to recharge. I've read the old posts that suggests hitting it with a big charge (75 amp) for a short period and that will allow it to be charged normally. I ried that and it is not working? I have a decent Die Hard charger that goes through an assessment of teh battery before it begins to charge and I get the fault flashing light every time? I've tried all the settings - Type I and Type II, along with the trickle charge, standard and 75 amp start charge and nothing? My latest attempt is to put a trickle charge on it and see if that works? Any ideas/suggestions?
Thanks in advance!
lapuwali
post Oct 17 2005, 04:19 PM
Not another one!
IMHO, a lot of "trickle chargers" are basically too smart for their own good. I used a plain old tech stupid charger that had no "sensing" of anything, and has a switch on the front that selects between 6 and 12v, and 2 and 6 amps.
Leaving a near dead Optima on 12v and 2 amps for many hours (like 8-10 hours) brought it back. I suspect a Battery Tender or the like will work as long as the battery is nearly fully charged, but these things don't seem to work well when the battery has a low charge (any battery, not just an Optima). I've had terrible luck with Battery Tenders (the brand, not the idea), and don't recommend them.
btw, the "neglected" Optima I spoke of sat hooked up in a 914 that didn't move for nearly 6 months. The Optima in my 912 regularly goes for 6 weeks between uses, and I've yet to have it fail to start the car, after about 13 months of that sort of abuse.
vesnyder   Charging Opima Red Top   Oct 17 2005, 06:24 AM
Engman   BTDT - and it is going to cost you. The real downf...   Oct 17 2005, 07:19 AM
seanery   I had a deep cycle blue top in my 951. It was nice...   Oct 17 2005, 07:22 AM
groot   Take is to an auto parts store and have them test ...   Oct 17 2005, 07:33 AM
DougC   They have a 3 year warranty so couldn't you ju...   Oct 17 2005, 08:16 AM
smg914   VES, This won't help you now but the next tim...   Oct 17 2005, 08:25 AM
736conver     Oct 17 2005, 08:45 AM
anthony   I disconnect the battery when the car is parked in...   Oct 17 2005, 09:06 AM
dlo914   whenever we get a few optimas in the store (Autozo...   Oct 17 2005, 10:41 AM
horizontally-opposed   There is a new charger on the market that CAN brin...   Oct 17 2005, 10:59 AM
Mueller   I thought you could recharge the Optimas if you us...   Oct 17 2005, 11:49 AM
lapuwali   I neglected an Optima until it was down to 10v, th...   Oct 17 2005, 12:26 PM
dmenche914   Ditto on that my red optima sat and died, many yea...   Oct 17 2005, 12:46 PM
horizontally-opposed   Exactly, the key is a low charge for a long time. ...   Oct 17 2005, 02:00 PM
Mueller   <...   Oct 17 2005, 02:26 PM
vesnyder   Brought the Optima into a battery dealer and they ...   Oct 18 2005, 05:30 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:58 PM
