(UN)bypassing a fuel pump relay.., going from Carbs to FI. |
DougC |
Oct 19 2005, 09:24 AM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
PO of my car ('73 w/D-jet) had installed carbs and had the fuel pump under the gas tank. The FP was wired directly to the #8 fuse on the panel, and the ground attached at some point above the fuse panel I believe. Anyway I want to go back to having the FP run through the relay on the board in the engine compartment since I'll be using fuel injection. So I disconnected the wire going to #8 fuse (+ FP wire) and made a connecting wire to the Black/Red wire at the front right hand side of the engine compartment which was originally used for the FP. This didn't work to energize the FP at all, nothing when I turned the key and I'm not sure why. Can anyone tell me what I'm missing? There is a FP relay in the board that I believe is good.
Doug C |
ClayPerrine |
Oct 19 2005, 11:27 AM
Life's been good to me so far..... Group: Admin Posts: 15,514 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Doug,
It's not that simple. You have to have a relay in the start circuit to turn on the fuel pump when the engine is cranking, otherwise it will NEVER start. Then when the engine fires up, the switch in the air flow meter takes over and keeps the fuel pump relay grounded. Speaking of running, did you get it running yet? I will be available Saturday if you want some help. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:23 AM |
