(UN)bypassing a fuel pump relay.., going from Carbs to FI. |
DougC |
Oct 19 2005, 09:24 AM
Senior Member Group: Members Posts: 949 Joined: 6-July 04 From: Dallas, TX Member No.: 2,307 |
PO of my car ('73 w/D-jet) had installed carbs and had the fuel pump under the gas tank. The FP was wired directly to the #8 fuse on the panel, and the ground attached at some point above the fuse panel I believe. Anyway I want to go back to having the FP run through the relay on the board in the engine compartment since I'll be using fuel injection. So I disconnected the wire going to #8 fuse (+ FP wire) and made a connecting wire to the Black/Red wire at the front right hand side of the engine compartment which was originally used for the FP. This didn't work to energize the FP at all, nothing when I turned the key and I'm not sure why. Can anyone tell me what I'm missing? There is a FP relay in the board that I believe is good.
Doug C |
lapuwali |
Oct 19 2005, 12:15 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
I looked again, you're right. Duh on my part. Much more convoluted than I imagined, but this should work fine.
Doug, this is very similar to what I PM'd you about. |
Lo-Fi Version | Time is now: 7th June 2024 - 06:13 PM |
