| McMark |
Oct 21 2005, 11:43 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
I have seat belt mounts that have stripped threads. I'm wonding if HeliCoil's are strong enough in case of an accident. Logic tells me, yes they would be fine if installed correctly, but my gut is a little more nervous than my head. Can anyone tip the scales one way or the other for me?
| banksyinoz |
Oct 21 2005, 07:43 PM
finally getting back into it ![]() ![]() Group: Members Posts: 223 Joined: 17-June 05 From: queensland, aus Member No.: 4,293 Region Association: Australia and New Zealand |
this is probably the best option if u cant get to the other side of the panel in question (i havent had to look yet) if you can you could replace the nut (weld nut to 3inx1in 10mm thick plate if doubtful this seems to be a manufacturing standard) then away you go or just use a bigger bolt i know i certainly wouldnt use a helicoil |
McMark HeliCoil Seat Belt Mounts Oct 21 2005, 11:43 AM
ArtechnikA i have been down this path too, since there are *n... Oct 21 2005, 11:47 AM
Aaron Cox id be scared.
weld up and retap? <... Oct 21 2005, 12:58 PM
jhadler Yes, it's a welded in insert. But look at the ... Oct 21 2005, 01:03 PM
goose2 drill them larger and re tap for a bigger bolt? Oct 21 2005, 02:37 PM
dlo914 speaking of seat belts...has anyone tried installi... Oct 21 2005, 03:03 PM
McMark Early cars have the supports and threads in place ... Oct 21 2005, 06:33 PM
trekkor ![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 09:27 AM |
