Broke the throttle on the six, need CSOB ideas |
djm914-6 |
Nov 8 2005, 04:33 PM
Happiness is: Getting on the road Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
It's been a long time comming I suppose. The lever that the pedal pushes on has been tilting to the inboard until the throttle rod rests againts the floor board. Sometimes I'd attempt to bend it back, but most of the time I'd just del with the squeeking.
Well, there's no more squeek because the throttle lever of the pedal assemble broke off. I got the car home by bending he manual throttle lever just enough to catch the throttle cable end. I drove it by pulling back on the lever. Now, I need some ideas. I know that the six lever isn't so common. What's the changes of having this one welded up and reattached to the pin that goes into the pedal assembly? |
Eric_Shea |
Nov 8 2005, 09:00 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Fixed... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Being in the pedal biz, I've seen 1/2 dozen weekend weld jobs on those bell cranks (is that what they're called James?) I'd hate to see that happen to a -6 piece. But, here's where I exit stage left... it ain't my car. P.S. Not trying to dis your welding work... I've just seen a lot of bad ones. Hell I even tried it myself. I take all mine to Troy and have him "braze" (which is connecting two bits of metal using more heat than soldering, but less heat than welding; a filler material is added, usually bronze. The British usually call it "bronze welding", and scads of racing chassis were (and are) assembled that way) them. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:37 PM |
