> Broke the throttle on the six, need CSOB ideas
djm914-6
post Nov 8 2005, 04:33 PM
Happiness is: Getting on the road
It's been a long time comming I suppose. The lever that the pedal pushes on has been tilting to the inboard until the throttle rod rests againts the floor board. Sometimes I'd attempt to bend it back, but most of the time I'd just del with the squeeking.
Well, there's no more squeek because the throttle lever of the pedal assemble broke off. I got the car home by bending he manual throttle lever just enough to catch the throttle cable end. I drove it by pulling back on the lever.
Now, I need some ideas. I know that the six lever isn't so common. What's the changes of having this one welded up and reattached to the pin that goes into the pedal assembly?
lapuwali
post Nov 8 2005, 09:15 PM
Not another one!
QUOTE (Eric_Shea @ Nov 8 2005, 07:00 PM)
Fixed... (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
Being in the pedal biz, I've seen 1/2 dozen weekend weld jobs on those bell cranks (is that what they're called James?) I'd hate to see that happen to a -6 piece. But, here's where I exit stage left... it ain't my car.
P.S. Not trying to dis your welding work... I've just seen a lot of bad ones. Hell I even tried it myself. I take all mine to Troy and have him "braze" (which is connecting two bits of metal using more heat than soldering, but less heat than welding; a filler material is added, usually bronze. The British usually call it "bronze welding", and scads of racing chassis were (and are) assembled that way) them.
Thank you. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
djm914-6   Broke the throttle on the six   Nov 8 2005, 04:33 PM
ClayPerrine   Contact Rich Johnson. He had 5 factory throttle be...   Nov 8 2005, 04:37 PM
r_towle   post a pic...never seen one...if it can be welded,...   Nov 8 2005, 07:32 PM
jkeyzer   Are the pedal assemblies for the sixes really diff...   Nov 8 2005, 07:40 PM
Aaron Cox   the pivot plate that the gas pedal connects to is ...   Nov 8 2005, 07:45 PM
djm914-6   Hey Rich, What's the chances that a weld would...   Nov 8 2005, 08:05 PM
Eric_Shea   The crank isn't different except for the handt...   Nov 8 2005, 08:08 PM
r_towle   <...   Nov 8 2005, 08:12 PM
lapuwali   ...   Nov 8 2005, 08:35 PM
r_towle   brazing is also much weaker than welding. Rich   Nov 8 2005, 08:43 PM
fiid   Much is a deceptive word. It's possible to ge...   Nov 8 2005, 08:58 PM
Eric_Shea   Fixed... http://www.914world.com/...   Nov 8 2005, 09:00 PM
lapuwali     Nov 8 2005, 09:14 PM
lapuwali   ...   Nov 8 2005, 09:15 PM
Eric_Shea     Nov 8 2005, 09:20 PM
r_towle     Nov 8 2005, 09:43 PM
Eric_Shea   Your 914 is brazed (and they painted right over it...   Nov 8 2005, 10:09 PM
r_towle   ...   Nov 8 2005, 10:28 PM
fiid   <...   Nov 8 2005, 11:08 PM
djm914-6   Still no pics of the carnage as I haven't take...   Nov 9 2005, 07:32 AM
Eric_Shea   Hey, did you guys know that brazing is connecting ...   Nov 9 2005, 03:45 PM
r_towle   ...   Nov 9 2005, 04:49 PM
Eric_Shea   Sorry... http://www.914world.com/b...   Nov 9 2005, 05:05 PM
lapuwali   Hey, I'm the Mr. Smartypants in this thread......   Nov 9 2005, 05:08 PM
fiid   I confess to also attempting to bust a smartypants...   Nov 9 2005, 06:34 PM
r_towle   i likea good argument...or discussion...none taken...   Nov 9 2005, 06:50 PM
- Lo-Fi Version Time is now: 3rd March 2026 - 04:24 AM
