| djm914-6 |
Nov 8 2005, 04:33 PM
Happiness is: Getting on the road ![]() ![]() ![]() Group: Members Posts: 1,864 Joined: 6-February 03 From: Burlington MA Member No.: 248 Region Association: None |
It's been a long time comming I suppose. The lever that the pedal pushes on has been tilting to the inboard until the throttle rod rests againts the floor board. Sometimes I'd attempt to bend it back, but most of the time I'd just del with the squeeking.
Well, there's no more squeek because the throttle lever of the pedal assemble broke off. I got the car home by bending he manual throttle lever just enough to catch the throttle cable end. I drove it by pulling back on the lever. Now, I need some ideas. I know that the six lever isn't so common. What's the changes of having this one welded up and reattached to the pin that goes into the pedal assembly? |
| r_towle |
Nov 8 2005, 09:43 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
bronze is weaker than steel. Bronze is brazing, or soldering..it is using a liquified metal alloy to glue to pieces together. now, if the piece in question has beenbroken off ina butt joint way..or torn off, there is no reason that welding with steel mig wire, or tig...would do any harm to this piece. I have always been a CSOB,,,if the part is an original brazed 914/6 part...get it brazed... If the part broke(not at a brazed joint, because it would never break....brazing is so tough) then fix it with welding. I discount brazing because of the following facts. You cannot get paint to stick to brazing...it will always lift off, so will bondo..ask any body guy about brazing and paint.... If brazing was better than welding structurally, bridges, cars, buildings, and a wide variety of other steel connections would be done with brazing because its easier, cheaper and would produce less heat and less warping etc... but its not the right method to fix a broken piece of steel that is under stress... Rich |
djm914-6 Broke the throttle on the six Nov 8 2005, 04:33 PM
ClayPerrine Contact Rich Johnson. He had 5 factory throttle be... Nov 8 2005, 04:37 PM
r_towle post a pic...never seen one...if it can be welded,... Nov 8 2005, 07:32 PM
jkeyzer Are the pedal assemblies for the sixes really diff... Nov 8 2005, 07:40 PM
Aaron Cox the pivot plate that the gas pedal connects to is ... Nov 8 2005, 07:45 PM
djm914-6 Hey Rich, What's the chances that a weld would... Nov 8 2005, 08:05 PM
Eric_Shea The crank isn't different except for the handt... Nov 8 2005, 08:08 PM
r_towle <... Nov 8 2005, 08:12 PM
lapuwali ... Nov 8 2005, 08:35 PM
r_towle brazing is also much weaker than welding.
Rich Nov 8 2005, 08:43 PM
fiid Much is a deceptive word. It's possible to ge... Nov 8 2005, 08:58 PM
Eric_Shea Fixed... http://www.914world.com/... Nov 8 2005, 09:00 PM
lapuwali Nov 8 2005, 09:14 PM
lapuwali ... Nov 8 2005, 09:15 PM
Eric_Shea ![]() ![]() |
Lo-Fi Version | Time is now: 3rd March 2026 - 04:25 AM |
