> Take shots at this idea......, I'm sure there's something wrong with it
East coaster
post Nov 9 2005, 07:19 PM
So, in the quest for some sort of damn heat/defroster I was curious if this could work.
In the really sh*tty diagram below, a coolant recirculation system that cycles coolant through the muffler to transfer heat from exhaust to coolant so it can be used with a heater core to supply heat/defrost.
I would expect that the tubing passing through the muff would need to be more than a simple tube and more likely an array of small tubes in parallel to better transfer heat.
Is this feasible or should I gently place the crack pipe down and call for help (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif)
TINCAN914
post Nov 9 2005, 07:44 PM
Summer's Commin...
QUOTE (trekkor @ Nov 9 2005, 05:24 PM)
I like it.
make a large flat "flask" that could be welded to the muffler with inlet and outlets.
And...If you do have a crack pipe, you really should put it down. (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif)
KT
(IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif) Harsh...
Well I got a laugh from it.. Sorry..but.. (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/chairfall.gif) Ok I'm done now.
East coaster   Take shots at this idea......   Nov 9 2005, 07:19 PM
trekkor   I like it. make a large flat "flask" that could b...   Nov 9 2005, 07:24 PM
SLITS   coolant velocity in the system is a critical facto...   Nov 9 2005, 07:26 PM
TonyAKAVW   What about coiling tubing around the exhuast? You...   Nov 9 2005, 07:26 PM
fiid   it would work - but why not just do heat exchanger...   Nov 9 2005, 07:27 PM
porschecb   They must have some really GOOD crack in NJ! I...   Nov 9 2005, 07:28 PM
bmunday     Nov 9 2005, 07:44 PM
Dr. Roger   what's wrong with the stock setup?   Nov 10 2005, 09:43 AM
effutuo101   Back in my 4x4 days I took copper tubing and wrapp...   Nov 10 2005, 10:01 AM
Kerrys914   I think it would be easier to use a small oil cool...   Nov 10 2005, 10:28 AM
jsteele22   A couple of thoughts... 1) Cooling the exhaust ga...   Nov 10 2005, 11:19 AM
SirAndy     Nov 10 2005, 12:57 PM
Mark Henry     Nov 10 2005, 01:48 PM
Dave_Darling   <...   Nov 10 2005, 03:11 PM
goose2     Nov 10 2005, 03:27 PM
fiid   50/50 antifreeze and water raises the boiling poin...   Nov 10 2005, 03:35 PM
Andyrew   How about running an oil cooler on the front grill...   Nov 10 2005, 03:49 PM
- Lo-Fi Version Time is now: 30th April 2026 - 11:27 PM
