| East coaster |
Nov 9 2005, 07:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,931 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None
So, in the quest for some sort of damn heat/defroster I was curious if this could work.
In the really sh*tty diagram below, a coolant recirculation system that cycles coolant through the muffler to transfer heat from exhaust to coolant so it can be used with a heater core to supply heat/defrost. I would expect that the tubing passing through the muff would need to be more than a simple tube and more likely an array of small tubes in parallel to better transfer heat. Is this feasible or should I gently place the crack pipe down and call for help (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) Attached image(s)
| goose2 |
Nov 10 2005, 03:27 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
I've heard this also...from those who have tried them. I think the gas heater is probably still the best option....had one in an old Corvair once when I lived in Michigan and it really cooked. Anybody know the price range on these? |
East coaster Take shots at this idea...... Nov 9 2005, 07:19 PM
trekkor I like it.
make a large flat "flask" that could b... Nov 9 2005, 07:24 PM
SLITS coolant velocity in the system is a critical facto... Nov 9 2005, 07:26 PM
TonyAKAVW What about coiling tubing around the exhuast? You... Nov 9 2005, 07:26 PM
fiid it would work - but why not just do heat exchanger... Nov 9 2005, 07:27 PM
porschecb They must have some really GOOD crack in NJ! I... Nov 9 2005, 07:28 PM
bmunday Nov 9 2005, 07:44 PM
Dr. Roger what's wrong with the stock setup? Nov 10 2005, 09:43 AM
effutuo101 Back in my 4x4 days I took copper tubing and wrapp... Nov 10 2005, 10:01 AM
Kerrys914 I think it would be easier to use a small oil cool... Nov 10 2005, 10:28 AM
jsteele22 A couple of thoughts...
1) Cooling the exhaust ga... Nov 10 2005, 11:19 AM
SirAndy Nov 10 2005, 12:57 PM
Mark Henry Nov 10 2005, 01:48 PM
Dave_Darling <... Nov 10 2005, 03:11 PM
goose2 ![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 11:27 PM |
