| East coaster |
Nov 9 2005, 07:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,931 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None
So, in the quest for some sort of damn heat/defroster I was curious if this could work.
In the really sh*tty diagram below, a coolant recirculation system that cycles coolant through the muffler to transfer heat from exhaust to coolant so it can be used with a heater core to supply heat/defrost. I would expect that the tubing passing through the muff would need to be more than a simple tube and more likely an array of small tubes in parallel to better transfer heat. Is this feasible or should I gently place the crack pipe down and call for help (IMG:http://www.914world.com/bbs2/html/emoticons/smoke.gif) Attached image(s)
| fiid |
Nov 10 2005, 03:35 PM
Turbo Megasquirted Subaru Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,828 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
50/50 antifreeze and water raises the boiling point up to about 250 degrees F.
I think you'll get enough heat, but building and maintaining the system will probably be more of a pain than buying a set of headers with HEs on. You can also sell on your existing headers to help offset the cost. It might even be cheaper. Fluid systems are hard enough when you have an existing thermostat and water pump and you're just trying to get everything working right. Something like this I think you'd have to do some work to stop it boiling over. With my Subaru conversion, I could reliably boil my cooling system before it got to temp because one of the coolant hoses went too close to the header/up-pipe - so I'm reasonably sure there is enough heat there. But it did boil the system over. Took me a long while to track the problem down. |
East coaster Take shots at this idea...... Nov 9 2005, 07:19 PM
trekkor I like it.
make a large flat "flask" that could b... Nov 9 2005, 07:24 PM
SLITS coolant velocity in the system is a critical facto... Nov 9 2005, 07:26 PM
TonyAKAVW What about coiling tubing around the exhuast? You... Nov 9 2005, 07:26 PM
fiid it would work - but why not just do heat exchanger... Nov 9 2005, 07:27 PM
porschecb They must have some really GOOD crack in NJ! I... Nov 9 2005, 07:28 PM
bmunday Nov 9 2005, 07:44 PM
Dr. Roger what's wrong with the stock setup? Nov 10 2005, 09:43 AM
effutuo101 Back in my 4x4 days I took copper tubing and wrapp... Nov 10 2005, 10:01 AM
Kerrys914 I think it would be easier to use a small oil cool... Nov 10 2005, 10:28 AM
jsteele22 A couple of thoughts...
1) Cooling the exhaust ga... Nov 10 2005, 11:19 AM
SirAndy Nov 10 2005, 12:57 PM
Mark Henry Nov 10 2005, 01:48 PM
Dave_Darling <... Nov 10 2005, 03:11 PM
goose2 ![]() ![]() |
Lo-Fi Version | Time is now: 30th April 2026 - 11:28 PM |
